A very wobbly delta using the full 1500mm sticks and CNC aluminum corners. its running on a smoothieboard at 24v. i used 3 FSRs under the bed instead of a probe on the effector to keep it light. i went with the flyby extruder situation like on the wasp printer because it keeps the extruder close the the hotend for flexible filaments but also does not move around, it kinda just rotates. total build volume is 300mmx980mm.
THE delta
Build in 'Delta Bots' published by deltajegga, Nov 17, 2018.
probably as big as you'd want it...
iSka, Tony Layne, rumopi and 7 others like this. -
Build Author deltajegga, Find all builds by deltajegga
