UPDATE SEP 23 2019
this design is CC BY
Fusion 360 files are here Fusion
lots of changes since the below summary
TITAN-XY is a large CoreXY 3d printer with a fixed Build plate and XY Gantry that moves along the Z axis
Current build is based on Openbuilds Vslot with 40x40 extrusion for the vertical beams
Single Nema 23 Z motors drive 4x acme screws that raise and lower the XY Motors and Gantry
Completely fixed build plate keeps prints stable.
Current Specifications
X Build volume = 295mm actual available motion
Y Build volume = 385mm Max (300 usable)
Z Build volume = 340mm Currrent (400 once complete), can be easily upgraded to 900mm
Aluminum Heated bed with Silicon heater and Glass and PEI Print surface, Buildtak Magnet flex plate system used
X & Y use 0.9 degree Nema 17 Motors with 14tooth GT2 9mm Pulleys
Z used 1.8 degree Nema 23 Motor
Duet Wifi controller used, 24v power supply
Direct Drive Bondtech BMG Extruder, E3D V6 Volcano, LDO 0.9 Cool Power nema 17 Stepper,
BLTouch bed probe
X & Y Axis using cheap chinese MGN12 Linear rail and carriages, (dual rails on X to enable easy carriage mounting, and to increase rigidity
Design was inspired by H-Bot & C-Bot
Link to Work in progress - Build of Material List
Link updated for public access
TITANXY (Fixed Build Plate, Quad Z Screw, CoreXY)
Build in 'H-Bot and Core XY' published by Adam Filipowicz, Sep 24, 2019.
Super Rigid CoreXY 3D Printer
Fusion 360
Sergio Deleon, d.luke_1987, Joaquin Marco and 19 others like this. -
Build Author Adam Filipowicz, Find all builds by Adam Filipowicz
not happy with my Makerfarm i3v 12"
