      It was a pretty easy task, but messy at first, no design on paper i just started by thinking of what I needed, I need a universal base plate for each machine I needed 3, I also needed1 quick disconnect for each tool,I also wanted to make it a breakaway, that's where the magnets come in,if you go out of boundaries it will detach
        Be sure to follow the instructions on how to mix,or your part wii not cure right,unless you by the more expensive quick set resin,the resin i used took 24 hours to cure,so it will take a few days to make all the parts.
    To make it easier to change tools
    Utube videos
    1 Epoxy resin kit Link
    1 Magnets Link
    1 Molds Link
    1 Screws and nuts m4 Link Used for aligment
    1 Mounting screws Link
