V-King - Design Benefits
- High performance design
- Rigid all V-Slot linear movements
- Light XY carries for high acceleration and jerk
- CoreXY linear moving top gantry
- Big build volume with less frame space
- Low maintenance design
- All running V-Wheels
- No gliding movements with bad bearings/bushings or bent rods
- All belted movements on XYZ
- No bad lead screws and nuts causing wobble and backlash
- Limited complexity
- Accessible standardized hardware
- Easy to print the parts
- Easy to assemble
- Easy to use
- Easy to service
- Using open source firmware and standard components
- e3d V6 hotend
- e3d Titan extruder
- Nema 17 Stepper motors
- MKS Gen 1.4 Ramps controller
- Marlin firmware
V-King CoreXY
Build in 'H-Bot and Core XY' published by Roy Berntsen, Dec 12, 2018.
V-King CoreXY 3d Printer- 380*340*340 Build volume - All wheels on V-Slots - Belts on XYZ - High quality and controlled design - Proven fast, reliable and it is all open source
More info here:
V-King CoreXY 3D Printer – The Smoothest Ride!
For all latest iterations go to the Github Repository
RoyBerntsenDesign/V-King
Cerberus, Hosseinmp, Paul Stoller and 14 others like this. -
Build Author Roy Berntsen, Find all builds by Roy Berntsen
The V-King Pro 3d Printer is a CoreXY cubed 3d printer which evolved through an extensive design process starting early 2017
The idea for the V-King design came when researching the Hypercube 3d printer. Through this phase I came across the KISS CoreXY printer which had some interesting design benefits over the Hypercube by Tech2c
Using the linear rails in the frame with all rolling parts seemed like a very good idea and the research, design and prototyping started taking place
The result of this process over about 12 moths is now a tested – fully working model with high quality design and print results
/RoyInspired by
Jean-Daniel Begin - KISS CoreXY -
Qty Part Name Part Link Comments 0 Link -
