In this build we will put together a quick easy to assemble belt driven linear guide.
If you are interested in purchasing the V-Slot™ Linear Actuator Bundle (Belt Driven) Bundle please click here.
Build Video
This linear actuator is modular, so there are may ways to build this version and they can be expanded to create large machines.
Please see example models for ideas
Note* This build could have also be done using the Mini V Plate and Mini V Wheels as well as the new V-Slot Gantry Plate - 20mm version for a smaller gantry system. Instead of the larger Universal Gantry Plate.
In fact anytime you are mounting the gantry to the 20mm side of any size V-Slot the Mini V and the V-Slot gantry plate (20mm) can work as the gantry plate.
V-Slot gantry plate - 20mm version examples
The modular nature of the OpenBuilds V-Slot™ system allow for limitless build possibilities!
Download example model in the Files tab at the top of this post, to use these examples in your own builds
NEMA 23 Motor Mount plate examples
TIP: You can open 2 instances of SketchUp and copy and paste between both of them.
V-Slot® NEMA 17 Linear Actuator (Belt Driven)
Build in 'ACTUATOR' published by Mark Carew, Oct 25, 2019.
Quick and Simple V-Slot Gantry System. This example build shows how easy it is to make a linear actuator using a few OpenBuilds Parts. You can mount this system an many ways so be sure to download the example models.
Praveen.R, Austin Ngugi Nyoike, farshid and 5 others like this. -
We built this as an example to help get projects started. This is a foundation build that is a good starting point for any build. -
