This build is another great example of how versatile the OpenBuilds modular building system can be.
This easy to build linear actuator utilizing a belt drive system displays an easy solution for smooth linear movement.
In addition, due to the modular design of this system it can be transformed into a building block for many lightweight applications.
We encourage you to make this bundle your own and don't forget to share your ideas here on
OpenBuilds
If you are interested in purchasing the V-Slot™ Linear Actuator Bundle(Belt Driven) Bundle please click here.
The modular nature of the OpenBuilds V-Slot™ system allow for limitless build possibilities!
Pulley Tooth Count: 20 teeth. GT3 Belt Tooth Pitch: 3mm per tooth. Steps Per Revolution for the Stepper Motor: 200 steps (1.8° per step). Microstepping Setting: 1/8th microstepping Steps per mm are: 26.67 steps/mm
Build Video
3D Model
Examples
Gallery
Build in 'ACTUATOR' published by Mark Carew, Aug 20, 2024.
iman ghassemi and Darriel Fisher like this. -
To display how easy it is to build a linear actuator with OpenBuilds Parts.Inspired by
OpenBuilds Nema 17 Belt Driven Actuator -
