This build is a pair of screw type linear actuators connected to create an X-Y stage.
What makes these actuators unique is that the acme threaded rod does not run beyond the length of the carriage to a receiving plate with an idler bearing. Instead this assembly allows the acme rod to be concealed inside of the carriage creating a nice minimal compact system.
While this may limit the stroke length it has its place in smaller systems such as the one shown in the examples. Larger assembles can be made as well, as long as the carriage is lengthened.
In this build you will learn about how many of the OpenBuilds parts work together creating a modular linear system.
Note: The OpenBuilds 3 way cube connector can also be used in place of the 90 degree block connector for a different look that adds.
Example Pics
* The V-Slot can be any length and size (check example model) you desire, as long as it can contain the length of the ACME rod inside of the carriage cart (Check model for example) In the example we are making a small stage that has a gantry V-Slot rail length of (210mm) with a gantry cart length of (100mm) the ACME rod length for this setup is (130mm) this leaves us enough room for the ACME rod to fit without hitting the end plates on the end of the V-Slot carriage.
This is the material list for building one linear actuator. To connect a second actuator (as shown in the pictures) X Y stage you will need (4) more V-Slot Corner Connector 90 degree angle to tie the two stages together - http://openbuildspartstore.com/v-slot-corner-connector-90-degree-angle/ or 3 Way Cube http://openbuildspartstore.com/v-slot-corner-connector-three-way-cube/
I hope you find this a useful build that inspires you to use and modify and adapt to your own projects.
Thank you
-Mark C
Please download and study the included model file for more options in creating these actuators with different sizes of V-Slot.
V-Slot™ X -Y Stage Hidden Acme Rod Example
Build in 'Everything Else' published by Mark Carew, Sep 17, 2015.
An X-Y Stage created from two self contained acme screw linear actuators. This build was published as an example of how many of the OpenBuilds Parts can be used.
crispin, Alfred Broda, sfbayman and 1 other person like this. -
To demonstrate how to build a compact and clean XY table using V-Slot -
