Update:
Here is a short video of it printing a tree frog. I have not finished the extruder calibration yet but it is printing pretty good.
Building upon the great work done by Marshall Peck and others.
I wanted a larger build area, stability, low part count and a easy to access tool holder.
Information on the starting point of this build can be found here:
Voxel OX - Extendable 3D Printer and CNC Platform | OpenBuilds
I increased the size of the build to accommodate 500mm z-axis lead screws from openbuilds.
The printer will start with a E3D V6 Lite hotend and will be controlled with a Azteeg controller running Smoothie Firmware.
I am including build dimensions and pictures of the build in process.
Control Board Mounted - Changed to SmoothieBoard
New Z-Axis
Hot End/Tool Mount
Back Side of Tool Mount
Front View
3D Drawing
Ortho View
Rear View with Dimensions
Top View with Dimensions
Voxel OX Based Build
Build in '3D PRINTER BUILDS' published by jjcolletta, Dec 29, 2015.
Building upon the great work done by Marshall Peck and others. I have started a new build.
Vic Cutter likes this. -
Build Author jjcolletta, Find all builds by jjcolletta
I wanted a larger build platform compared to my homebrewed printer. Also I wanted stiffer mechanics to support other types of working ends. I am thinking of adding a simple cutter in the future.
When it is completed and running it will get a dual hotend and the old printer will become something else.Inspired by
Marshall Peck and others -
