Floating head assembly.
WLOG (WIP)
- I had to use only parts I already have.
- Z axis and floating head should be extendable - I want to have possibility to replace plasma torch with drag knife or other tools when needed.
Some tests with markers.
1. Floating Head Plate
- V-Slot Gantry Plate 20-80mm
- 4x Aluminum Spacer 6mm
- 4x M5 12mm screws
2. Z limit switch plate
- M5 10mm screw
- Nylon Insert Lock Nut M5
- L Bracket Single
3. Floating head wheels assembly
- 4x 30mm Low Profile Screws
- 4x M5 Slot
- 4x Nylon Insert Lock Nut M5
- 4x Precision shim
- 2x Eccentric 0.25in spacer
- 2x Aluminium 0.25in spacer
- 4x V Wheels
4. Floating part
I created custom plate from 2mmx20mm aluminium flat. It will be used as metal part for proximity sensor/switch.
- 2x T-nut
- 2x Precision Shim
- 2x M5 8mm Standard screw
- 1x M5 8mm Low profle screw
- Custom Top Plate
- 200mm 20x40 V Slot Profile
Plate sketch:
Assembly:
Two screws will act as limit for profile from falling down. It will stop at V-Slot Gantry Plate.
Assembled:
5. Assembly of floating part with floating head plate
6. Floating head proximity sensor/switch
- Custom alumiunium plate
- Custom 3D printed model
- Proximity sensor M12 NPN NO
- 2x M5 8mm low profile screws
- 2x M5 12mm low profile screws
- 2x Nylon Insert Lock Nut M5
Plate sketch:
Proximity holder:
7. Connecting to linear actuator 250mm
8. Z Axis limit
Assembled:
W|W plasma/drag knife 1500x1500 (floating head & z-axis)
Build in 'Plasma Cutter Builds' published by wojak, Feb 6, 2019.
Step by step designing and implementing of my plasma approach
Build Author wojak, Find all builds by wojak
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Ff3a76e40-dae6-4857-8218-c1d21c3ee936%2F2019-02-06_0104.png&hash=607cea583bf567e363ef8de5713c5946)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F572a21f5-ed06-43d1-bd34-58af432d744e%2F2019-02-06_0107.png&hash=51acba80a7bc3f658c7ee8a2f7ce156a)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F235dc97d-53ea-4d69-82db-f5d33c408cf3%2F2019-02-06_0113.png&hash=f78b183ed1b6fce4b4462865f4ae879c)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Ff27ab54f-95ac-4272-b503-a1ef796b28b5%2F2019-02-06_0116.png&hash=8553d6b239a3dd8a1492402ac449efac)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F9fd743ca-257c-4334-abf3-e3c68063a54c%2F2019-02-06_0135.png&hash=2e455868d5915bce933660025e76c329)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F681ee443-c71d-4ac1-9955-3ba5a9ffbf0a%2F2019-02-06_0147.png&hash=868cee18e6b4ab9cb09a69d584b09d0a)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F06cc5ea5-07fd-417b-83bb-b59e7a0e6a23%2F2019-02-06_0157.png&hash=7f4088d3b4d0121e8ac6372241982f24)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Fb33f7cf9-1eb5-4a5b-acf6-a79f68fb8888%2F2019-02-06_0152.png&hash=3628cbe804b7b957bfe8b3e28b603fed)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Fd17d521c-03e0-4506-9d7a-e0fd35633318%2F2019-02-06_0159.png&hash=2d7106ed1b7853e68c1413c8447e74ce)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F7bd4ec5b-4cf3-4780-b541-17d7cbaa7459%2F2019-02-06_0217.png&hash=7fc9c5f07e24c3b0d09a1fa066503a3e)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Fae43113f-5fdc-4083-8273-b24d631a3be1%2F2019-02-06_0213.png&hash=b3ba0de851033b9736e03ed2c71eee88)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F4e099764-6197-4822-86e7-5458fe9dedae%2F2019-02-06_0221.png&hash=728d7874366320efdbb11bb891472494)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F045ae045-399c-4150-9d8e-6671831ce500%2F2019-02-06_0227.png&hash=f5919e3c04d9c07f2c056f59b798e01f)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F78d1501b-92da-4595-96bb-03b86a9cb94c%2F2019-02-06_0234.png&hash=9ba29c8994a03e2ae7bfb300f5a7eeb1)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F1023c23c-92ef-4431-8d37-fefdbe1de6ef%2F2019-02-06_0230.png&hash=d8d818a9172e21b7d0d7b9c03f8db8f9)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F27a85f22-9780-4e50-b406-5a0c2c12c45f%2F2019-02-06_0232.png&hash=54c09c4278c81ea2fd167caed4fca0e3)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2F07e81fa4-f66b-4053-ac50-67b010e810df%2F2019-02-06_0240.png&hash=e93c61add228c3e65b1a95b0b5273a6f)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Fa8ad8cc5-8787-48c4-8126-b64e4d047d8d%2F2019-02-06_0244.png&hash=8b11ac7451699b4a11cc977f2c4f857e)
![[IMG]](proxy.php?image=https%3A%2F%2Fcontent.screencast.com%2Fusers%2Fbaael%2Ffolders%2FJing%2Fmedia%2Fdc27fb52-d4d5-42ac-b99e-14746dbca421%2F2019-02-06_0243.png&hash=0c8e57c265262d75b98058532d82ab30)
