hope you can see the photos if not I can send you photos
workbee 1510
Build in 'CNC ROUTER BUILDS' published by jeff johnson, Mar 5, 2020.
Getting more height out of the !510
Build Author jeff johnson, Find all builds by jeff johnson
to gain height, I was having issues with a 3/4" spoiler board and could barley fit a 3/4" board to cut -
Qty Part Name Part Link Comments 4 linear rail https://openbuildspartstore.com/v-slot-20x40-linear-rail/ Link 1500MM rails - I cut off 1.5 inch to fit 4 Black Angle Corner connector https://openbuildspartstore.com/black-angle-corner-connec... Link these will be added to the top rails front/rear rails when moved to the outside of the bracket 4 End Cap https://openbuildspartstore.com/end-cap/ Link These were added under the newley addd corner connectors 10 L Bracket https://openbuildspartstore.com/l-bracket/ Link singles added for wate board since 1 new rail was added, 4 doubles were added to mount the 4 new rails, the triples i had were cut to doubles
