Phoenix controller and Estlcam
Discussion in 'Control Software' started by Srednasoft, Aug 27, 2020.
  1. Srednasoft
    Has anyone used Estlcam 11.231 together with the controller card Phoenix by Hayri Uygur.
    The controller is based on Arduino Uno and runs GRBL 1.1f
    Estlecam will update the chip to its own firmware. Will that work on this card?
    5189BAC1-05FC-42D6-9C8F-16E6AA3B828D.jpeg C55DAC90-FE17-4816-BAA0-BC667DDD5CFD.png
  2. Giarc
    It should work. In the setup in Estlcam choose GRBL 1.1.
    Srednasoft likes this.
  3. Srednasoft
    The problem is that Estlcam wants to write a new fw to the controller. Its own fw, that supports grbl 1.1. Will the Estlcam fw work on the controller?
  4. Rob Taylor
    Any "grbl controller" is just a repackaged Arduino Uno- this Phoenix, the BlackBox, all of them. They're hardware projects to make it easier and safer to interface the machine to the ATMega328p MCU IC.
    If it's grbl-compatible, it's almost certainly Estl-compatible.
    There are still inherent risks to reflashing firmware, though.
    You can avoid flashing, use it as a CAM only, export gcode and send the gcode using your normal workflow
  6. Srednasoft
    Ok, so it’s a risk, but it should most likely work ok
