Workbee 1515 Blackbox Settings
Discussion in 'CNC Mills/Routers' started by DxN32, Sep 22, 2019.
  1. DxN32
    DxN32 New
    Finally finished building the computer and got everything hooked up. So far the only problem I’m having is the 1515 is not in the machine select drop down box. I selected 1510 just to get the ball rolling. If anyone could help my out with dimensions and settings to set, I would appreciate it very much.
    Very happy with everything, now it’s time to wire up the VFD and spindle. Can’t wait to make my first test programs/cuts.
    Thanks in advance
    OpenBuilds doesnt sell a 1515 so you would need to configure it yourself. Scroll down and play with the relevant setting.
    Github.com/gnea/grbl will be of help too
    Good luck
    MFCarew likes this.
  3. P.Abraham
    P.Abraham New
    Hi there,
    I've got a 1515 machine too. I'm also a total noob to this and I'm sure I'll get the hang of it in time. Just wondering if the only thing that needs to be adjusted is the x and y travel?
    DxN32, any settings you may have settled on would be awesome!
    Thanks guys
