z axis mechanical looses
Discussion in 'CNC Mills/Routers' started by mlowka, Aug 31, 2020.
  1. mlowka
    mlowka New
    How do I reduce mechanical looses on the z axis? i've tightened all the screws (I think so). I'm attaching a film to show the problem.
  2. Christian James
    Christian James Journeyman
    You need to adjust the screw on the anti-backlash nut to remove the slop. Problem is, its something that really should be done during the assembly stage as its not easy (maybe impossible) to get at while the Z axis is mounted.
  3. mlowka
    mlowka New
    Thank you! Do you have an idea what's the best (the least invasive) way to get to it. Which parts i have to remove?
  4. Christian James
    Assuming you fitted the anti-backlash nut with the adjustment screw on top, remove the motor and top C beam cover plate, you should see the backlash nut. Lower the C beam as far as possible to get better access. The challenge for you is getting a spanner on the nut and an allen key on the adjuster. It's best to remove the router because of the weight,prior to adjusting.
  5. mlowka
    mlowka New
    Thanks!
    Could also be that the stop collars weren't pressed up tight against the ends
  7. Christian James
    Yes, another good point Peter. That can be checked by lifting the Z C-beam from the bottom and checking for movement but you will get some movement from the motor coupling compressing so don't count that!
    No you shouldnt? There must be stop collars on both ends. One would never rely on a flex coupling to apply force axially
  9. mlowka
    mlowka New
    So, I've checked the stop collars- they sit tight.
    I got to the anti-backlash nut (see photo) what do I do next? How should I regulate it?
    Something looks wrong here, but hard to see from that photo. Bearing should be into the recess..
  11. mlowka
    mlowka New
    I've tightened the nuts :) There's a slight improveent, but I think it moves not only up and down but also back and forth (video)
    Tighten eccentrics on the wheels
  13. mlowka
    mlowka New
    thanks :):):)
    it worked :)
  14. Christian James
    Didn't make myself clear. What I meant was, if there is movement up and down don't look at the coupling, look at the stop collars because if they do have play, it will show in the coupling.
  15. mlowka
    mlowka New
    Christian James :) the good thing is I've learned how the machine is build :):):)
