Frauthy 3D Printer
Discussion in '3D printers' started by MechEng, Aug 8, 2014.
  1. MechEng
    MechEng New
    MechEng published a new build:
  2. Mark Carew
    @MechEng Great looking machine, thank you for sharing!
  3. Seul Kee
    Seul Kee New
    I also thank you for your detailed explanation.
  4. Funk
    Funk New
    Awesome. That sure looks like it was designed in SolidWorks. Any chance of getting the part and assembly files?
  5. MechEng
    MechEng New
    Hey!
    Sorry for the delayed response. School can be pretty time consuming!
    I do have the SolidWorks files, and I plan on submitting them here once I can package them in a professional manner.
    Happy holidays!
  6. Keith Davis
    Keith Davis Veteran
    A suggestion on your change to 60x20 X axis extrusion - move the single wheel on the outside to the center slot instead of the same top slot as the inside top wheel. The resulting triangle will let you adjust the wheel-to-rail tension only on that wheel (assuming the other two on the other side are true)
    Great progress. This looks like an easy to build design. Make a great kit.
  7. MechEng
    MechEng New
    Good thinking! Will try that out asap.
  8. bobs987
    bobs987 New
    This looks like a great built, Solid. I'm currently sourcing parts for this now, can’t wait to bust the saw out! I too would love to see the assembly files, I'd like to scale it up to accept a 10"x10" bed if not 12"x12". It looks like this can be done by extending the z and x axis members. Is there anything I'm overlooking?
    MechEng, Great idea extending the x axis for more a more ridged build and the suggestion Keith Had is spot one. Will definitely be doing this to my build. Happy Holidays, enjoy your winter break.
  9. MechEng
    MechEng New
    Yep you would pretty much just extend the axis proportionally for a larger bed.
    The current lengths I have for the frame for a 200mm x 200mm x 200mm build volume are:
    - (1) 20mm x 80mm x 590mm for the y axis (front to back)
    - (1) 20mm x 60mm x 365mm for lower width of frame
    - (1) 20mm x 60mm x ~510mm for x axis (left to right)
    - (1) 20mm x 40mm x 365mm for upper width of frame
    - (2) 20mm x 40mm x 385mm for height of frame
    A person could probably just barely get a 250mm x 250mm x 200mm (10" x 10" x 8") build volume with those dimensions, but it would be a really tight fit.
    Couple things to note:
    - I'm using a Budaschnozzle hot end, and have it set to drop ~10mm below the x-axis plate and 30mm (from the plate surface to tip of nozzle) out of the x-axis plate. You might consider the depth of the extruder you plan on using before cutting the y-axis extrusion. You should still be fine if you're doing a direct drive extruder, but some of them can get pretty beefy and it's probably just best to check before you make that cut.
    - The solid shaft couplings I have are just slightly too wide at 24.75mm diameter to fit into the pocket behind the x-axis. If I had slightly thinner solid shaft couplings, I would be able to get an additional 30mm of z travel.
    - Currently, my 8mm lead screws are ~370mm in length. I did this so I could experiment with different captive nuts if need be. You can still use 300mm lead screws for 200mm of z travel if you use brass captive nuts or put a taller captive nut oriented length-wise up the lead screw. This is what I'm currently using, but I haven't been able to test their longevity/ reliability:
    http://www.ebay.com/itm/Brass-Flange-Nut-For-DIY-Build-3D-Printer-Z-Axis-8mm-Stainless-Steel-Lead-Screw/141428125155?_trksid=p2045573.c100033.m2042&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20131017132637&meid=f835724c6a97455d8e0da864e344d63d&pid=100033&prg=20131017132637&rk=3&rkt=4&sd=381018039835
    - I didn't end up putting the additional bits of 20x80 under the printer. I thought it would help make the printer more rigid, but they just took up space and required more brackets.
    - I'm doing Bowden extrusion. I ended up making a spool holder out of 20x20 that sits behind the printer because I couldn't come up with a place to mount the extruder on the frame where the Bowden tube didn't put a weird bend in the filament. PLA isn't very friendly with sharp turns.
    I think that's about all I really changed. Let me know if you run into any issues.
    Currently working on making a clean looking Ramps/ Arduino enclosure, a micro-fine z-stop mount, a geared (metal) bowden extruder, and a LCD mount. Will post those files here once I confirm they're good to go.
  10. MacSpengo
    MacSpengo New
    great build. I have a questions though. How did you mount the wheels on the back side of the X axis? I do not see any plates in you BOM and was just wondering how you did it. Could you post a picture of this as well? Great looking setup, I am building one right now.
  11. MacSpengo
    MacSpengo New
    Never mind. If I would have read your update, my questions would have been answered with pictures.
    Great work, looks fantastic. Hope to have mine up and running tomorrow.
  12. bobs987
    bobs987 New
    Wow thank you for the detailed reply. I cant wait to get this going, Starting to order the parts this week. I have to build a new desk first, Current one is a bit on the small side. How is the Bowden setup working for you? I've read both good and bad things about this setup.
  13. bearwood
    bearwood New
    These updates look like they will do the trick. The solid shaft couplings are a must.
    I had a huge amount of fun and learnt so much building my rendition of the original design. I added a open builds Cube connector to add the 3rd wheel to each side of the X axis gantry.
    I changed the drive over to CoreXZ which is working really well now that I changed over to a Bulldog driven bowden system.
    I look into the Y axis drive that you've suggested, as although it works ok, it adds more length which I'm not sure is needed.
  14. MacSpengo
    MacSpengo New
    Would you be willing to share a stl file of your captive nut adapters? It looks like a much easier approach than drilling the metal plate.
  15. MechEng
    MechEng New
    I was using a budaschnozzle because that's what I use on my other printer, but I wanted to see how light I could get the x assembly, and I also wanted to maybe dabble in printing polycarbonate.
    For now, I've set aside the budaschnozzle and I'm trying a dual bowden setup utilizing Prometheus hotends.
    http://www.dta-labs.com/products/prometheus-hot-end-v1-1
    Here's a shot of my current extruder setup:
    http://i.imgur.com/bLmKs4r.jpg
    I haven't ran any test prints with the new extruder, but I did with the budaschnozzle. It printed pretty good, but I was using some really horrible filament where the diameter was 3 +/- 0.2mm. When I get this dual extruder setup all bolted up, I'll be sure to post some pictures of the first test prints. Kind of a side note, but if you're going with bowden, I would definitely recommend Ultimachine filament. It's pretty expensive, but the diameter and quality is so consistent, nothing else really touches it.
  16. MechEng
    MechEng New
    Sounds pretty slick!
  17. MechEng
    MechEng New
    I was hoping to release all finalized files at the same time, but I suppose it wouldn't hurt to release one file.
    Just keep in mind, things could change, or I might change the design for some reason, so use at your own discretion.
    I've posted the adapter plate in the, "files" tab.
  18. Huey Brantley
    What stage are you currently in? Close to releasing everything?
  19. MacSpengo
    MacSpengo New
    This is fantastic. I was able to get these printed out and they worked like a charm! Thanks so much for posting these, I have been taking pics of the build and will be posting them soon.
