Control software shows Black Box Probe is on
Discussion in 'General Talk' started by Bill Jennings, Feb 26, 2020.
  1. Bill Jennings
    Control software says probe is turned on and X-limit is turned off but X-limit is connected. black box.JPG
    Seeing as these two are on opposite ends of the controller, sure you didnt just plug in starting from the wrong side?
    As in instead of X/Y/Z/PROBE you started at PROBE/Z/Y and left X open?
    #2 Peter Van Der Walt, Feb 26, 2020
    It's not "being connected" that shows as ON, its when the switch is closed/triggered/axis is hitting the switch to indicate end of travel - that's when it light up. If it lights up as ON all the time, check your $5 setting (or change from NO to NC wiring, or NC to NO, depending on what you are doing / which switches you have
  4. Bill Jennings
    I had everything connected right after downsloading usb files everything is right.
  5. Don O
    Don O New
    I am using a Duet 2 and after adding new limit switches they show triggered when not engaged and not triggered when they are. Do you know how to change that setting?
  6. Don O
    Don O New
    Does anyone know how to change the limit switch settings from NC to NO on a Duet2 board?
  7. Alex Chambers
    Config.g
    M574 (Gcode)
    Change S1 to S0.
    PS - if it's a question about the Duet post in a new thread - grbl users get confused about the Duet (and vice versa) :p:)
