Blackbox
Discussion in 'Controller Boards' started by ricklach, Sep 9, 2020.
  1. ricklach
    ricklach Well-Known
    Is there enough juice in the blackbox to drive a single NEMA 34 step driver (plus drivers for the x and Z axis (NEMA 23)?
    Depends ln the specs of the NEMA34.
    Coil rating in the 3-6v range, and current up to 3.2A (even if motor is rated higher in its peak rating, see if the torque curve is acceptable in the 2.5-3A range) will work.
  3. ricklach
    ricklach Well-Known
    OK, Thanks.
  4. callis11
    callis11 New
    Sorry, I’m new in the cnc world and trying to understand steppers and limits to blackbox. Would a nema 34 4.5Nm 5.5A .4ohms 2.2v 3.5mh+-20% work with the blackbox and would it give more torque over the nema 23 high torque from openbuilds currently sells?
    It should work (nice low voltage coils) and should be a little more powerful, even if running at about half of maximum amps. The 3.5mH inductance may require a little more gentle acceleration, just keep in mind when tuning your parameters
