Workbee not moving on x and y What have I done wrong ?
Discussion in 'CNC Mills/Routers' started by Jake Borg, Sep 27, 2020.
  1. Jake Borg
    Jake Borg New
    x and y are doing the same thing. Belts have been tightened but motor is not moving when I try to jog it from the pc. I have attached a video and photo of x motor
  2. Alex Chambers
  3. Jake Borg
    Jake Borg New
    I got it from ratrig Portugal controller blackbox with the software from this website. it's a 1510 build belt drive. I adjusted the power on the blackbox for x motor and seemed to work but i dont like the way it sounds not sure if it's supposed to be this noisy Y motors still dont move when I adjust their power
  4. Alex Chambers
    Ratrig are usually pretty good on support. Which instructions did you follow for wiring the motors? (colour coding is not standard) I helped someone recently who had got their machine from Ratrig, but followed the Openbuilds wiring instructions - turned out the colour coding on their motors was different, which is why I posted that link above.
  5. Jake Borg
    Jake Borg New
    il have a look at it when I'm back on the PC color wires are attached correctly but if motors color coding is not the same sounds like that could be the problem
  6. Jake Borg
    Jake Borg New
    I found the wiring diagram for the motors I was sent from what I can understand is the color codes are not the same for each coil pair as open builds video setup. My question now is how shall I switch them around to mimic the same setup with the y 2 motor inverted as in the video ?
  7. Jake Borg
    Jake Borg New
    sorry forgot to attach the diagram
