G Code pause
Discussion in 'Control Software' started by Mike Latimer, Sep 29, 2020.
  1. Mike Latimer
    We have just setup a X Y plotter 1.2 m x 2.4 m using open build parts and a Black box controller.
    What we are trying to do is very simple.
    We are wanting to setup a measurement grid of 50mm squares, 1.2m x 2.4m.
    At each intersecting point on the grid we want to pause for 30 seconds take a measurement then go to the next point and repeat.
    We can make G code for the grid no problem, but how do we get our measurement head to pause for 30 sec and continue to the next point.
  2. Giarc
    #2 Giarc, Sep 29, 2020
    Mike Latimer likes this.
  3. Giarc
    Just a quick check to be sure and I found GRBL does support the G4. gnea/grbl
  4. Alex Chambers
    But I think with grbl the pause is in seconds rather than milliseconds as it would be in "standard" g-code.
  5. Giarc
    You are probably right. I guess we would have found out if I was wrong 8.333 hours after the first attempt. :) I have never messed with the G4. I assumed ms because of every other arduino project I do is ms.
  6. David the swarfer
    While the pause has its attractions I don't like it..... how do you know when to take the measurement? travel time between every point will not be equal.
    I would rather integrate the Gcode generation and the sampling into one script, so the script will send a move command, wait for the 'OK' from GRBL, then sample, then move, etc.
    Then you know for sure that no sample was taken while still moving.
  7. Alex Chambers
    LOL - I embarrassed myself by getting this wrong about a year ago - not sure why grbl decided to be different on this one.
  8. David the swarfer
    not GRBL that is different from anything in the Gcode world, the RS274 Gcode standard and LinuxCNC's interpretation of it says seconds
    G Codes
    GRBL is essentially NOT an Arduino project, while you can compile and flash it using the Arduino IDE it uses not a single line of Arduino library code, it is pure C/C++, therefore you can compile and flash it with a number of other ATMega compilers AFAIK.
  9. Rob Taylor
    Yep, that. I've flashed it directly from Windows command line in the past with AVRDUDE. Easier with the Arduino IDE, but that's also just a stub to generate the hex from the library files, no real "Arduino" code there.
    Arduino just happens to be the most convenient form factor for the ATMega328p.
  10. gsw
    gsw New
    Hi i would like to ask about the G4 dwell time, i am using the Black box control system, i am setting up a very basic system and wanting the Z axes to go down and pause for 3 seconds and return back home. but i cant get the dwell time to work. does it work in the black box code or is there another way to achieve my z axes move with a wait time of (seconds). any help would be helpful.
  11. Rob Taylor
    All you should need to write is G4 P3, that's it. G Codes
  12. gsw
    gsw New
    thanks for your reply, when i put the G4 P3 in the code and simulate it, it doesn't pause. will it pause in the simulation in the open builds control simulation.
  13. Rob Taylor
    That I don't know off-hand, though if the simulation uses grbl's hardware simulation mode then it should. I'd just do a very short hand-code and run it straight on the machine. Only need to move a few mm to be able to tell whether it's performing as expected.
    G90 G21 G17 G54
    G53 Z0
    G1 Z-10 F500
    G4 P3
    G0 Z0
    M30
    Something like that. Change the G21 to G20 and the Z-10 to Z-0.5 if you're working in imperial units. Home first, obviously.
    Simulator is eye candy :) run it on the machine!
    sharmstr and David the swarfer like this.
  15. gsw
    gsw New
    Thanks for the info, the dwell (G4) works on the machine but not in the simulator. that was throwing me off.
    Kerry Thurber and sharmstr like this.
  16. Kerry Thurber
    I just upgraded versions (1.0.270 now) and the simulator pauses, but it doesn't matter what number you put in there, it will pause the same amount
    Thanks for the report, try the Beta of 1.0.272 - modified 3D viewer being built: See Control crashes on large files?
    #17 Peter Van Der Walt, Jan 6, 2021
  18. Kerry Thurber
    Thank you I will do that.
    Hey who's writing the simulator? I'm a coder. Can I help?
  19. Peter Van Der Walt
    OpenBuilds/OpenBuilds-CONTROL accepts pull requests :)
  20. Kerry Thurber
    I misspoke. There is a minute pause between commands in the simulator. My G4 commands in version 1.0.270 are not processed.
  21. Peter Van Der Walt
    The sim does not handle pauses, it just gets the array of points, and moves between them with the approximate feedrate
