Jogging - Black Box and OB Control
Discussion in 'General Talk' started by Mark Lytle, Dec 17, 2019.
  1. Mark Lytle
    Those of you guys using GRBL and OB control...is there a way to disable the double click function on the jog?.....Example:
    Im setting z and my finger jumps essentially clicking it twice quickly like a Double Click..then it goes in the desired direction non stop unless acted on ...cost me a brand new 1/16 amana but
  3. Mark Lytle
    Thank you for responding-- its onlyhappened once --- but lol
  4. Mark Lytle
    Ok on to my next woe lol-- I have looked till Im looking at the same things :0) -- how can I change the 3d view -- EXAMPLE-- when i zoom, it zooms right away from the machine tip icon moving around-- and i cant drag the view around
  5. Greg Stanczak
    It appears that the endless jogging on accidental double-click issue's status is complete (?) but I am still having the issue, not with a double-click on the mouse or track pad buttons but with double-clicking on the track pad, itself, only. Empty brackets with some spaces also appears in the command line in the Serial Console at the time of endless jogging, although entering this directly into the command line does not reproduce the problem.
    Thanks,
    Greg
    Keyboard Jog Bug · Issue #73 · OpenBuilds/OpenBuilds-CONTROL is still an open bug. :) click slower for now, or use Incremental for more precise control
    The empty brackets is just queue management (no command in queue, thus nothing between the brackets. The brackets are just something we add around a known command to make it easier to read)
    #6 Peter Van Der Walt, Oct 3, 2020
  7. Greg Stanczak
    Thanks, Peter.
    By far the nicest program for sending g-code, in my opinion!
    Regards,
    Greg
