Motors Slipping Under Load
Discussion in 'CNC Mills/Routers' started by Jake Borg, Oct 7, 2020.
  1. Jake Borg
    Jake Borg New
    Hi guys I am trying to cut out a small sign in 5mm acrylic using a workbee 1510 with Nema 23 Stepper Motor - 1.8degree/step, 175oz-in Problem im having is the pocket inside the cut is working fine but when i come to cut out the outside of the sign the motor seems to be slipping. The motor itself is slipping not the tension belt.
    What could be the problem ? Feedrate 1300 mm/min
    Plunge 700mm/min
    Cut Depth: per Pass 1.25mm
    Endmill Diameter 6.35mm
    Controller Blackbox
    #1 Jake Borg, Oct 7, 2020
    Most likely: loose setscrews on the pulleys. If the setscrews go loose, the motor shaft can slip inside the pulley
    - Make sure to have a setscrew on the Flat side of the D shape of the motor shaft
    - A couple drops of Locktite, between the pulley and the motor shaft to prevent slipping
  3. Jake Borg
    Jake Borg New
    I don't think its the shafts, I tried holding the axis on with my hand while jogging it on the PC, i can't seem to see the shaft moving, it more looks like the motor itself is stalling.
  4. Alex Chambers
  6. Jake Borg
    Jake Borg New
    Depends on the climate of your workshop, ambient temp etc. The red indicator will tell you when it overheats
    Where's the motors from? Datasheet? (if not from us, might just be incorrectly spec'ed)
  9. Jake Borg
    Jake Borg New
    Ok cool, their wiring color code differs from our motors, but the basic specs (coil voltage, inductance and current rating) are pretty similar
    Do check those again please, we tend to see the loose setscrews on pulleys reason for slipping quite often (because of the tiny hex, you can't tighten them very well for fear of stripping) and while they may look right, can slip under just the right load
  11. JustinTime
    The reason why I always change them, on all my machines, to regular Allan screws.
  12. Jake Borg
    Jake Borg New
    I think I may have found the problem the v slots got some acrylic bits in them which is causing the wheels to get harder on some places which may be causing the motors to stall due to more force needed. Now I need to figure out where to get a dust shoe for my makita rt0700cx4
    Me too!
  14. Giarc
    Mee too. I also grind a small flat on the lead screw.
  15. Alex Chambers
    Blue (non-permanent) loctite is the solution for the drive pulleys on a belt drive. Re dust shoe you could always make one - search the forum for ideas.
