New guy here
Discussion in 'General Talk' started by Rod13, Oct 14, 2020.
  1. Rod13
    Rod13 New
    Just build my Lead 101x10 I have a problem with the movement of the x axis. Each time I press the x button I get a loud sound sometime it move a millimeter. I took a video of it but unable to upload. Amy help appreciated.
    Thanks Rod
  3. Rod13
    Rod13 New
    Thanks for the help. I re-did the wires. Also check the coupling on the lead screw to the motor, I think that was the problem. Maybe not position right on the motor shaft or lead screw. Any ways no weird sound and move smoothly.
    Rod
    Great stuff. Yeah a little loctite on the grubscrews helps a lot too! And make sure to have one of the motor-side setscrews on the flat of the D-shape of the motor shaft
