Where do I position the Z-axis endstop switch?
Discussion in 'CNC Mills/Routers' started by Duncan Meyer, Oct 24, 2020.
  1. Duncan Meyer
    As you can see from the attached photo, I'd like to have the Z-axis stop just shy of the Z-axis end plate. But I can't figure out where or how to position the end stop switch.
    I have a 16mm spoilboard, and I will mainly be cutting 18mm plywood, which doesn't give me many mm to play with. Every position i can think of makes the end stop switch protrude past the Z-axis end plate.
    Suggestions?
  2. Duncan Meyer
    I also have one of the OB XYZ touch plates, but there's no room on top of the plywood to deploy it...
  3. Christian James
    Christian James Journeyman
    Image from Workbee Build video.
  4. Giarc
    I did it the hard way. I must not have been thinking clearly the other day. Maybe I should watch the assembly videos. :) Mine required grinding away a good portion of an aluminum right angle bracket...which is actually easy with a disk sander. At least it is a pretty shade of orange.
  5. Duncan Meyer
    My switches are a different shape/size to the one showed in the build video. I've managed to get mine pretty darn close, but my soldering is something only a mother could love. So I've taken the chicken way out and ordered a few of the end-stop switches from the parts store. My next challenge is to test the full travel of the axes. So far I've got the X-axis travelling the full 1300mm, but have discovered that the cable management is way too tight at about 1250mm - so I'm repositioning them. I need the full 1300 x 1270 travel for the work I'm going.
  6. Ronald4418
    Ronald4418 Well-Known
    You guy's really have me confused now. With Z-0 or Home Position being at the top of the Z-Travel Limit why would you need a Z-Limit Switch when the Controller Softwares Parameters are posted in the Configuration Files?
  7. Giarc
    I am not sure I understand your question. The z limit is put in a position to mark the top of the z travel for homing. If you do not have the switch, you can not home. I do not have any switches on my CNC mill, so I have homing disabled on that machine. I just jog to where I want to start cutting and set the XYZ zero there.
  8. Ronald4418
    Well that's what I thought, I have my Z-Home Switch at the Top of my Travel Limit and the Total Z Travel registered in my GRBL File. Which is a Basic Soft Limit as I had used in Mach3 and or UCCNC. I then Probe at X-0, Y-0 and follow that with my Tool Setter Probe set at that point for My Z-0. I add in the clearance above Z-0 for my Rapids and start to cut. I thought I had it configured wrong for some reason after reading the above comments.
  9. Giarc
    Sounds like you have it right to me.
    Homing enables you to better utilise Machine Coordinates (for example Fusion360 uses machine coordinates for its Z Safe travel moves). Without switches you would have to "fake the home" and its a royal pain compared to having switches
    Ronald4418 likes this.
  11. Duncan Meyer
    My question was related to where to physically attach the Z-stop so that its body clears the wheels, but the roller at the end of the switch arm makes good contact. I have had to position the switch at an angle, and add an extra screw to the bottom wheel. I'll post a picture shortly. It works, but looks messy. I was just wondering how other people do this.
    See earlier reply above ^
