Error??
Discussion in 'Control Software' started by baum, Oct 26, 2020.
  1. baum
    baum New
    Im trying to pocket some text to do an inlay. Its programmed in f360. As its clearing the pocket i get this error? any way around it?
  2. sharmstr
  3. baum
    baum New
    This is the one im using. I have the full version of f360 so i have the older one
  4. David the swarfer
    #4 David the swarfer, Oct 27, 2020
  5. David the swarfer
    the other thing to try is to check your lead in and lead out radii. fusion likes to use a formula that produces a radius that is a small fraction of the bitdiameter and this can be very small, and now and then, too small to be calculated properly to 4 decimal digits and you see error:33 as a result.
  6. baum
    baum New
    I will give that new post a try. Just as a follow up i re-did the cam work using solidworks and hsm works and it worked great. same post as i was using in fusion..
