OpenBuilds Blackbox Relay
Discussion in 'CNC Mills/Routers' started by SeanD, Nov 5, 2020.
Tags:
  1. SeanD
    SeanD Well-Known
    Setting up a pen mount and solenoid to “engage” the drawing mechanism. On the OpenBuilds Blackbox I intend to use the external plug for the 24v Relay out to a step down converter into a 12v solenoid.
    Is the external plug for the 24v relay able to be turned on or off with a GCode command? I think the documentation states I can do this with M3 and M4 but just want to check.
    Also I can’t get hold of a 24v solenoid quickly, will stepping down the 24v to 12v have any specific issues?
    Thanks in advance.
    The relay output is just a "switch". Wire it into the 12v line to your solenoid.
  3. SeanD
    SeanD Well-Known
    Doesn’t it output 24V?
    No, it's a relay only (normally open, closes when it gets a signal, signal is defined here docs:blackbox:jumper-relay [OpenBuilds Documentation])
    It's actual mainly intended function is for docs:blackbox:connect-plasma [OpenBuilds Documentation] (closes the two wires that normally would be the little switch on the plasma torch that you'd press by hand)
    The COOLANT ouput outputs 24v: See docs:blackbox:connect-coolant [OpenBuilds Documentation] - controllable with M8/M9
    For Pen Plotter, why not use a Servo instead of solenoid though: docs:blackbox:connect-rc-servo [OpenBuilds Documentation] - you'll find more CAM support for M3 Sxxx where xxx = pen position
  5. SeanD
    SeanD Well-Known
    Oh sorry I see now. If I hook my 24V power supply in line with it it would switch that power.
    I already have my coolant port turning on and off my vacuum shoe, air pump and coolant solenoid value with M8/M9.
    I only wanted to use a solenoid or a linear actuator because I want to have the pen off to the side of my router spindle to make bebe lines and figured all I have available is a 24V output from the relay on the Blackbox.
    Sounds like unless I replace the spindle functionality I only have an on/off relay to deploy the pen.
    Sorry for scrappy drawing, I just drew it up in like 2 minutes.
  6. SeanD
    SeanD Well-Known
    I think this is the one I have. I don’t think I have ever seen that other one for sale here in Australia.
  7. SeanD
    SeanD Well-Known
    Out of all the photos I have on my phone this is the only one that shows that part of it and I am not sure if that’s the servo part in the corner or not.
    Yeah seems to be one of the old V2.4s
    Can still wire up a servo from the PWM pin
  9. SeanD
    SeanD Well-Known
    I am not understanding that part of the documentation. It looks like I do have the 3 pins above my power for gnd, 5V and sig. Documentation looks like I can’t use the servo and my spindle at the same time though. Is it an “instead of” or an “as well as”.
    I was going to use Relay port if possible so it does the draw and cut in one job.
    Grbl only has one PWM output (spindle or servo) yes (so spindle, OR servo)
    The M3/Spindle/PWM signal is ONE output in grbl, goes to Relay via Jumper, goes to 0-10v circuit for spindles, goes to PWM pin on TOOLHEAD, and the SIG pin of the Servo header. Grbl has one output, we provide many alternative outputs of that one signal depending on what they have to control (plasma? use relay, IoT relay- use PWM pin, Servo - use the Servo header or PWM pin, PWM controlled DC spindle, use PWM pin, Laser - use PWM pin) but at the end of the day, all of those, are from one Grbl output
  11. SeanD
    SeanD Well-Known
    Thanks for your help. It obviously can't be done then as there is only one output from GRBL. I might look at what I can create with a push button that the machine moves to coordinates to engage instead then. Thanks for your time.
  12. Luis_Mtz
    Luis_Mtz New
    I don't speak to much english, i would like to know which code i need to use if i want to active my Relay2, i have a Blackbox X32, i bought a C-beam.
    M3 and M4. Relay 2 is Direction for the Spindle
  14. umbacos
    umbacos New
    Hi, is the relay a clean contact? Eg. I can connect 12V on one pin from an external power supply and gcode M8 closes the contact to the other pin?
    umbacos likes this.
