need help with blackbox running vfd spindle and laser
Discussion in 'Laser Cutters' started by FrankM2020, Nov 10, 2020.
  1. FrankM2020
    hello group. Hoping that someone can help. I have blackbox and spindle working correctly however when I try to run a laser job the laser doesn't fire without the spindle . I've read all the documentation I can find on the subject. have remove the relay jumper, and tried a dbl throw switch on the on the 0-10v plug on the controller. Have no idea what I'm missing here
    Grbl has only one PWM output (used for the 0-10v signal too), so control which one reacts by turning the spindle's power off if you want laser, and laser's power off if you want spindle :)
  3. FrankM2020
    I was hoping that wasn’t the answer. Thanks again for your help. Wouldn’t be as far along as I am.
