OX AI
Discussion in 'CNC Mills/Routers' started by Robert Hummel, Feb 3, 2014.
  1. dddman
    dddman Journeyman
    Welcome back! :)
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    The two 4 plate sets that require a light sanding are packed and ready
    PM me for info on price and shipping
  3. Robert Hummel
    Moderator
    Ty my friend, as per our conversation on Facebook I think I can swing the custom heat bed for our Deltas and believe 250mm would be the perfect fit :)
  4. GrayUK
    Glad you are back my friend. :thumbsup::thumbsup::thumbsup:
    Gray
  5. Robert Hummel
    Moderator
    Since the last two" light sanding needed" four plate sets went so fast
    I have made 3 more.
    PM for info ;)
  6. DiggerJ
    DiggerJ Journeyman
    Got any Yaxis end plates laying around with your belt attacment system on them? I gotta take mine apart, and think they might work better than the T-nut attachment system
  7. Robert Hummel
    Moderator
    Yes I do my friend, they need a light sanding and belt clips milled, I have kit I'm finishing up that someone backed out of due to financial issues so I will mill the clips tomorrow and pack them up while I finish the kit
    I have bin real busy tweaking my OX AI files and working on my Delta.
    Finished up the files
    "fully compatable with OB parts"
    I will be putting them in order and tagging them as version 1.2 for future reff and posting them in the files section of my build
    Here's a pic of what my Delta is looking like, need a few more parts from OB and the Fiber OX will be cutting the cork for my heatbed :)
    Nick W, Hytech2k and mybuild14 like this.
  8. DiggerJ
    DiggerJ Journeyman
    I got my steppers and 20x40 V-slot yesterday. Are you milling carriage plates for the 20x40? I am starting to print part today and am starting with the carriage template and vertices. We are going magnetic counterbored pucks with ball bearing ended rods.
    What is the size of your Delta frame?
  9. Robert Hummel
    Moderator
    Yes me and dddman are working together on a version of the Delta 6 build.
    My horizontal 20x40 is 300mm long, Vertical are 680mm leaving 600mm between vertex
    I designed carriage plates to match the plastic parts, tested and made adjustments in turn dddman adjusted the printed parts.
    The end result is this :)
    I must say dddman has got some printing skills
  10. DiggerJ
    DiggerJ Journeyman
    I agree. He does have skills. I need to modify the Infill3d magnetic carriage files to match that size carrier plate.
    We are going a very similar direction, but I really like the movement of the BerryBot. I figure I will start with the harder one, and can always come back to bolt-ons. Let me know if you are selling those carriage plates. I have the wheels and everything else in stock.
    Check these:
    http://www.thingiverse.com/thing:496689
    http://www.thingiverse.com/thing:501250
    http://www.thingiverse.com/thing:494853
  11. Robert Hummel
    Moderator
    Here is a shot of me test fitting the acrylic shield/brace
    Jestah, mybuild14, Steve123 and 2 others like this.
  12. DiggerJ
    DiggerJ Journeyman
    Very slick! I thought about something like this with a ledge over the edge just a smidge. Then puttin a slitted cover over the top slott
    that would fold away as the carriage passed by it. As it passed, it would fold back down. Blocking the dust while down, pushing it away while folding back as the gantry went by.
  13. sgspenceley
    sgspenceley Veteran
    I read every post tonight, it was awesome to see a side business grow, so quickly. It really shows when a true artist and craftsmen produces something special customers buy from all over the world.
    I love the work you have produced. I'm a newbie here but started my inspired Robert aluminum OX build. Thank you Mark for such a wonderful design and forum.
    Thank you for the inspiration...
    Steve
    #403 sgspenceley, Dec 9, 2014
    Robert Hummel and GrayUK like this.
  14. Robert Hummel
    Moderator
    One side done, gotta get some more hardware before I can do the other
  15. Robert Hummel
    Moderator
    Both sides done and wow what a difference in the way the wheels run.
    Having the inside support really helps keep the wheels squared in the v-slot
  16. Hytech2k
    Hytech2k Veteran
    Looks good !
  17. mybuild14
    mybuild14 New
    Looks great Robert. Are you going to post the acrylic shield/brace files? I sure would like to take a stab at cutting some when my OX is up and running. Thanks to you and everyone for the great additions to the original OX.
    Dave (MYBUILD14)
  18. GrayUK
    Hi Robert.
    I'm interested to hear these help to stabilise the wheels. Would you make that a standard fixture now? They look good, but your stuff always does!!
    Do you think if, from the top, to say 20mm below the wheels, it were to protrude each way along the "Y", almost forming a "T", and allowing it to ride over the end support aluminium strips at each end, it would give even greater protection to the belt from the dust etc?
    Just a thought.
    Gray
  19. pmany
    pmany New
    Or something like the attached, just a quick creation in Sketchup for demo of idea. This would allow cross pieces to have more support of Y in the middle of the "C". It would not be as strong for the wheel support, but what you lose in support you should make up for in less deflection of Y.
    I had been contemplating making something like this that would have horizontal wheels also....
  20. Robert Hummel
    Moderator
    Yes the files will be released as a full zip with all files to reproduce the OX AI :)
    it helps loads with alignment, as to your idea I kinda get it but a picture is worth a ton load of words :)
  21. Robert Hummel
    Moderator
    Most up to date version OX kit ready!
    First come first serve ;)
    Packing it up now
    Contents
    4 x Custom Main plates
    4 x Custom ends plates
    2 x Custom Z plates "universal NEMA17-23"
    3 x Nema23 spacers
    1 x Name plate/brace
    4 x M5x70 bolts
    2 x 608z bearings
    6 x Belt clips
    12 x M3 hardware for belt clips
    4 x Tie strap clips
    Mopar32985 likes this.
  22. Nick W
    Nick W Well-Known
    Message sent.
  23. Robert Hummel
    Moderator
    Update!
    Kit has sold, more will come :)
    Jestah and Nick W like this.
  24. Jestah
    Jestah Well-Known
    @Robert Hummel , Did you run double Excentrics on each lower wheel?
    If so do you need to use two different spanners to shnug them up at the same time?
  25. Robert Hummel
    Moderator
    Yes I did use 3 more eccentrics and 4 x 1/4" spacers per side
    I do one at a time in small amounts :)
  26. Michael Dunn
    Hello Robert, how much is this kit selling for? I am dying o build on of these.
  27. Robert Hummel
    Moderator
    I got some time and made up the terminal / drag chain plate and guard.
    It is held in place with 2 - Black 90s
    Has two 12 screw terminals and 16mm stand offs where used for mounting the guard :)
  28. GrayUK
    O.K! So where do you keep finding this "time"?? :jawdrop:
    Have you got a secret place you keep it?? :D
    With the amount of stuff you do, you have no right to find any spare time, as far as I'm concerned. :cool:
    Looks good though, as usual. :thumbsup:
    Gray
    Robert Hummel likes this.
  29. Robert Hummel
    Moderator
    Just a heads up folks, a full OX kit will be up for grabs if the person it was built for does not claim it by tomorrow.
    If you are in my list then you have priority unless it's gone before you see this post....... Ty guys
    P.S for the person that did not claim it feel free to contact me and I will put another kit together for you
    3 x Nema23 spacers
    4 x M5x70 bolts
    2 x 608z bearings
    6 x Belt clips
    4 x Tie strap clips
    Mopar32985 and sgspenceley like this.
  30. Robert Hummel
    Moderator
    Up for grabs guys ;)
