Carbide Create incompatibility with black box?
Discussion in 'CNC Mills/Routers' started by RFX, Nov 22, 2020.
  1. RFX
    RFX New
    I just got my lead CNC up and running and have had quite a bit of stuff I’ve been designing in Carbide Create while I waiting for the machine to arrive.
    My problem is I can’t get what I’ve made in Carbide Create to run on the machine.
    the open builds cam worked perfectly but I need an offline option which for me is carbide create. I also have vectricbaspire 9.5 But haven’t yet used it.
    Does anyone know what I should be selecting for post processor? GRBL isn’t working for me for some reason because it won’t run on the machine.
    Travis Good likes this.
  2. sharmstr
  3. Peter Sesselmann
    you need to replace some of the code.. I simply copy and paste a header each time I create a new file..
  4. David the swarfer
    please post a gcode file
  5. Peter Sesselmann
    I use the GRBL export and create a .nc file, then I open the file in a text editor and replace the following code at the head of the file:
    ______________________
    G90
    G21
    (Toolpath 1)
    M05
    M0 ;T2
    M03S18000
    _________________________
    with the following code:
    G21; mm-mode
    G90; Absolute Positioning
    M3 S1000; Spindle On
    G0 Z10
    ___________________________________
    I think some of the M commands are waiting for a response....
    Peter
  6. David the swarfer
    M0 means 'stop and wait for user to press go again', so either remove it or press run twice
