MadCAM Grbl Post Processor
Discussion in 'Other Software' started by Michael Collins, Nov 24, 2020.
Tags:
  1. Michael Collins
    I am wondering if anyone uses madCAM with their Black Box controller and if there might be a post processor for this.
    Otherwise, is it difficult to create the post processor?
    Thanks!!
  3. Michael Collins
    Thanks! I will give this a try, again.
    I am getting setup now with using Control and the Black Box as I was previously running Mach3 on a 32 bit system.
    I found this and installed, but I think there may be some issue giving me trouble. I created a simple 4” circle profile cut as a test but the actual circle is much smaller.
    I have already done the preliminary calibration.
    Perhaps this outputs in mm instead of inches?
    Another question is, how can we assign keys to control the jogging from our keyboard, or is there a keyboard shortcut for that already. Also, is there a way to have fine control over the jogging motion?
    In Mach3, pressing shift before using the jogging keys allows movements of .001”
    Sorry for so many questions.
    Do a test with known-working gcode first to see if machine is accurately calibrated
    docs:blackbox:hello-world [OpenBuilds Documentation] for example
    Or at least a known-working CAM
    G20 vs G21 - check the gcode. and of course is the scale off by 1/2.54 ?
    Wizards and Tools > Customize Keyboard Shortcuts
    Fine jogging: Use Incremental for finer control
    #4 Peter Van Der Walt, Nov 24, 2020
  5. Michael Collins
    Awesome!
    Thanks. I’m sure I will have more questions soon.
  6. Michael Collins
    So I believe the Shapeoko post processor is sending the output scaled to metric. Is there a simple fix to convert to imperial?
    //MadCAM_POST_2015-1-12
    *VERSION*
    1.0_031210
    *FILE_NAME*
    Shapeoko
    *FILE_EXTENSION*
    nc
    *FILE_DEST*
    c:\postfiles\
    *FILTER*
    0.005
    *OUTPUT_WIDTH*
    *OUTPUT_DECIMALS*
    *SCALE_X*
    *SCALE_Y*
    *SCALE_Z*
    *AXIS_1_CHAR*
    X
    *AXIS_2_CHAR*
    Y
    *AXIS_3_CHAR*
    Z
    *CUTTER_REFERENCE*
    TIP
    *RAPID*
    N"lnbr" G0 "x" "y" "z"
    *END_SECTION*
    *RAPID_APPROACH*
    N"lnbr" "x" "y" "z"
    *END_SECTION*
    *RAPID_RETRACT*
    *END_SECTION*
    *APPROACH*
    N"lnbr" G1 "x" "y" "z" F"feed"
    *END_SECTION*
    *FIRST_CUT*
    N"lnbr" "x" "y" "z" F"feed"
    *END_SECTION*
    *CUT*
    N"lnbr" "x" "y" "z"
    *END_SECTION*
    *TOOL_CHANGE*
    N"lnbr" T"toolnr"M6
    N"lnbr" S"speed"M3
    N"lnbr" G43 H"toolnr"
    *END_SECTION*
    *TOOL_STOP*
    *END_SECTION*
    *PROGRAM_START*
    O"pgmnr"
    N"lnbr" G40
    *END_SECTION*
    *PROGRAM_END*
    N"lnbr" M30
    *END_SECTION*
    *LINE_START_NUMBER*
  7. Michael Collins
    Adding a G20 command edit in the g-code seems to have done the trick. Now to dial in the calibration. I also need to figure out how to strip out some gcode which causes an error when running if not removed.
  8. David the swarfer
    those changes should enable you to output Gcode that needs no editing
  9. Michael Collins
    The post processor from the link seems to work but may need some tweaks.
    for some reason the Z axis F rate is the same as the X&Y F rate even when it is modified in the g-code.
    I would like the tool to have a slower plunge rate when entering the work.
    I have this set in my CAM software but it doesn’t write the g-code to reflect this.
    N1 G40 G20
    N2 G0 X-0.375 Y0.000
    N3 Z0.250
    N4 Z0.000
    N5 G1 Z-0.015 F5
    N6 X0.375 F15
    N7 G0 Z0.250
    N8 G0 X-0.375
    N9 Z-0.015
    N10 G1 Z-0.030 F15
    Thoughts?
    Contact MadCAM (or a more MadCAM orientated audience) for further assistance :) ?
    madCAM - Support or MadCAM as a paying customer, surely they'll be happy to advise on editing the post?
  11. David the swarfer
    I think madcam should put documentation on the web so this is easy to find!
    file C:\Program Files\madCAM 6\System\madCAM_Help.chm tells us what we need to know
    Attached you will find my GRBL post for madcam. Since I don't have a license for Rhino I cannot test it so let me know if you have problems.
  12. Michael Collins
    Thank you!!!
    Agreed. I wish they had more documentation on their site.
    I will give this a shot and let you know the outcome. Much appreciated!
    Cheers,
  13. Michael Collins
    So, the post processor is working quite nicely. Digging the Black Box upgrade from my Gecko drive and my old 32 bit system running Mach3.
    Thanks for the help folks.
