correct software
Discussion in 'Control Software' started by jeffreycncbeginner, Nov 26, 2020.
  1. jeffreycncbeginner
    I just took out my Mach3 chinese board and installed a Openbuilds Black Box motion controll. I do believe i have everything hooked up correctly. Now im stuck on the software/ drivers part. I have downloaded the file for the drivers from docs:blackbox:install-drivers [OpenBuilds Documentation]. But there is no instructions as to what one to use. I am connecting it to a China 6090. Currently using windows 10 pro with 64 bit can anyone help with the correct driver? Also, is there a way to hook up a digitizing probe to this black box?
    On the FTDI website linked from the page above, look at the table. What operating system are you using: then read that line across. For Windows there is a link at the very right hand side (last column) with a Setup Executable.
  3. jeffreycncbeginner
    awesome thanks. i was downloading the wrong one
