Lasersaur conversion to blackbox
Discussion in 'Laser Cutters' started by Aaronxyzee, Dec 12, 2020.
  1. Aaronxyzee
    Hello
    My lasersaur driveboard has recently died and I am thinking about using a blackbox controller.
    I have a few questions that I would love some answers to...
    Can I use the existing micro stepper drivers and motors?
    Can I hook up the chiller so that the machine will only work if the chiller is working?
    Can I use the existing magnetic proximity sensors/end stops?
    Any help gratefully received
    Best
    Aaron
    You can reuse the motors, but the drivers can go on a shelf for a future project as the BlackBox has onboard drivers
    Depending on the signal the Chiller puts out, yes. You can use the Door input as a pause when the chiller faults out. May need a Grbl recompile but not too hard.
    Been about 7 years since I last played with a Lasersaur, can you refresh my memory on what kind of sensors they used?
  3. Aaronxyzee
  5. Aaronxyzee
    Excelent. Thanks.
    You've probaly made a sale
    Best
    Aaron
