NEJE 30 Watt Diode LAser -- black box help
Discussion in 'Laser Cutters' started by Mark Lytle, Dec 12, 2020.
  1. Mark Lytle
    I hoping someone could help me out in beginners terms, we all had to start somewhere :0) I grabbed a DEJE 30 Watt Doide laser and am wanting to connect it up to my router table which runs all OB stuff, black box and control. I am totally lost on wiring for what I have and how to get it connected to the black box correctly other than positive and negative correct and use the toolhead port. The laser came with a small control board which is 12v, do I need this if I am connecting to the BB directly? Separate power supply or will it get power from toolhead? -- Super sorry as I am new and dont understand everything totally. Any help is appreciated, I have looked through the docs, however I am unsure if I have 3 wire or 4 aghhh! lol
  2. Mark Lytle
    update -- I will need theboard :0)
    Staring at this thing lol-- so connecting to the black box directly I should not need the small control board that came with it I think lol -- ----Looking at the 4 wire that came with it coming from the laser, the red/ black would be 12v power(laser is 12v, Ill order one ) and the yellow/green pwm and ground right? If anyone could comment would be awesome :0)
    thank you
    #2 Mark Lytle, Dec 12, 2020
  3. Mark Lytle
    Ok so reading around and stumbling through everything -- I have the laser working using the small board that it came with and understand the flow of it now (well I think lol) so output of that board had several options, 1 of which being the a 2 wire --- my question I guess now is once the jumper is removed from black box, will that effect the router at all-- so I would have to reinstall the jumper every time I wanted to use the router vs the laser? - I know I have to change the $ for router vs laser. Not sure why noone has chimed in, did i say something wrong ? lol
    Mark
    Nothing wrong said :) just no one has that laser probably
    Relay jumper is not used for Router. See docs.openbuilds.com > blackbox > IoT relay section, or VFD section. The relay is used as a Plasma trigger.
    You will have to change laser mode $32 yes
  5. Mark Lytle
    Thank you Peter-- just wanted to clarify :0)
  6. Josh whittaker
    hi ihave the same laser, i have enabled $32 and taken the jumper out but the laser still wont come on when i click "tool on"
    For wiring details of the module, refer to the supplier you purchased the module from. The PWM signal out of the BlackBox is just a PWM signal, the laser itself needs to be wired correctly and powered correctly
  8. Josh whittaker
    i see, i thought the PWM would supply the 12v to power the laser. looks like il need 12v dc power supply then?
    Generic laser documentation is in the docs: docs.openbuilds.com/blackbox but always cross reference the module's own documentation - we cannot document every module that exists unfortunately, so our documentation covers the generic concepts
  10. sutharvj66
    black box is 24volt and laser module is 12 v . how does it work?
