Nema 23 motors not following instructions
Discussion in 'General Talk' started by nm24, Jan 4, 2021.
  1. nm24
    nm24 New
    Setup on Lead CNC = Arduino Uno, CNC Shield V3, DVR8824. Using Easel to operate machine. When I go through the machine setup in Easel the X and Y motors work fine. The Y axis has two motors driving screws on each side. However when I press button to move Y forwards the Y axis moves forward if I press the button 4 or 5 times the axis moves forward 4 times and the one of the motors will go forward while the other one moves in opposite direction, twisting axis. When I press the button to move Y backwards this will happen 4 or 5 times, then one motor will move in opposite direction twisting axis. I have swapped wires as suggested in various sites but this has not solved the random change in direction of one of the motors. Help!!
  2. Alex Chambers
  3. nm24
    nm24 New
    Hi Alex, Thank you for that info Soldered all the wire ends and used smaller electrical connectors nd all worked fine.:thumbsup::thumbsup:
    #3 nm24, Jan 4, 2021
    sharmstr and Alex Chambers like this.
