Hi Everyone, I need some help with the above Error. I have tried several times to cut. I keep getting the same message below. I have checked the hard limit trigger switch. Nothing seems to be wrong with the switch. Also, I have checked the serial console. The message is below My hard limit switches are not lite. Any help would be greatly appreciated. Wayne V.
Did you ever figure out this issue. having the same problem. Looked through the black box documentation but could not find a solution. I'm going to uninstall and re-install the program
There are a whole lot of things listed in that link that you can check to see where the problem is coming from.
Refer to docs:blackbox:faq-emi [OpenBuilds Documentation] Onset of colder weather increases static charges in the air
