Is it possible to add legs to the LEAD 1515 instead of sitting it on a table?
Discussion in 'Concepts and Ideas' started by 22878, Jan 5, 2021.
  1. 22878
    22878 New
    I'm brand new to all this, so be nice to me, okay?! I was about to buy a LEAD 1515 kit, but then I noticed that the table you can buy for it isn't really a stand, it's just a table that you sit the assembly on. Is it possible to just add some legs to the 1515 so that there is no table underneath it?
  2. David the swarfer
    No I don't think so. Sitting on the flat table is part of what keeps the LEAD frame aligned (no machine tool is independant of the mounting arrangement, I can bend (measurable in 0.0001") my 120kg cast iron lathe with 2 fingers even though it is on a 100kg welded frame). if you attach legs directly to the frame, the legs have a lot of leverage and the slightest bump will put the frame out of alignment.
  3. 22878
    22878 New
    OpenBuilds Support just responded and they think it should be no problem. Anyone else know if it's possible and how to do it?
    "That's really the beauty of the OpenBuilds system in that it modular and so you should have no problems adding on legs to the LEAD machine. Sounds like it will be a nice Build and we look forward to seeing how it turns out please be sure to share it on OpenBuilds so we can all learn together."
  4. Rick 2.0
    Of course it can be done. You’ll just need to do a bit of resizing on the lengths of the table framing members. There is a big difference though between can and should. If your entire diagonal stability is based on your spoil board what happens when you pull it to replace it?
  5. 22878
    22878 New
    You can use a 3 piece spoil board and replace one piece at a time, would that be a problem?
  6. Christian James
    Christian James Journeyman
    It's not something I would ever consider doing, but you seem determined, so it's your choice.
  7. 22878
    22878 New
    OpenBuilds Support said it should be no problem at all. Do they not know what they're talking about or something? Why did they say it would be no problem, but everyone else thinks it's not a good idea to try it?
  8. Rick 2.0
    Attached is a Sketchup mashup of the 1515 with the table. Really doesn't work directly. Saves about $72 in rail but the legs interfere with the Y-axis gantries which cuts about 90mm off the usable Y-axis working length.
    To truly make it work you would need to squeeze in the side rails on the table a bit more but I've taken it as far as I'm going with it. If I were to build the combination I'd just cut the table down to the size of the system. A lot less wasted floor space that way.
    22878 likes this.
    Just to clarify their response:
    They are correct that using the modular parts catalog, you can add legs. But their expectation is that you would do the proper engineering of such a changed design (not just pop legs on the side). Ie add some triangles to stop racking, and read up about deflection: How to calculate V-Slot® deflection - the response doesn't give you a 100% confirmation to go ahead as-is
    They provide modular parts, and information, both of which, along with little engineering effort - together, can result in fantastic new designs and new builds.
    As they say: "we look forward to seeing how it turns out" - in other words - its not proven to work, but after you put in the effort to make necessary modifications, then please "be sure to share it on OpenBuilds so we can all learn". As in, go for it, try it, knowing that its a learning experiment and once its figured out, sharing it with the community so everyone can benefit from the engineering.
    #9 Peter Van Der Walt, Jan 7, 2021
  10. 22878
    22878 New
    Yes, that's the exact sort of design I'm looking for! Let me check it out in Sketchup.
  11. Rick 2.0
    Got some sleep and decided to give it another go. This revision resolves the Y-axis issues.
    Actually turned out rather nicely. Still needs a 20x20 rail to support the drag chain on Y2.
    Please remember, this is only a conceptual design. No actual build or testing behind it. The Sketchup drawing is a mashup of drawings created by two different persons that did not mesh perfectly so dimensions may not be accurate.
    22878 and sharmstr like this.
  12. 22878
    22878 New
    Yes, this looks amazing. Where did you get the drawings from? Are there models available for the different parts that you can import into Fusion 360 or Solidworks?
  13. 22878
    22878 New
    Can you upload just the LEAD 1515 drawing so I can compare it to the one with legs so see exactly what you changed?
  14. sharmstr
  15. Rick 2.0
    Best just to point you to the source of all things OpenBuilds | 3D Warehouse (sketchup.com)
    As far as the changes, the (6) 20x40 bed framing pieces on the LEAD were replaced with 20x60 members, 5 of which would have comprised the original top frame of the table.
    If anything else exists it can generally be found here. I don't work in those 2 packages so I have no idea what's out there.
    Edit: fixed link
    #15 Rick 2.0, Jan 7, 2021
    Click the RESOURCES tab above ^
    Rick 2.0 likes this.
  17. 22878
    22878 New
    I noticed that. You didn't have to change the lengths of any of the V-Slot rails between the 1515 and table? What about this issue attached? Do you think that corner bracket is necessary?
    #17 22878, Jan 7, 2021
  18. 22878
    22878 New
    Can someone confirm the dimensions on the 1515 table in this drawing aren't correct? I measured 1680mm for the V-slot 20X60 rails around the middle of the legs, but that length isn't available in the part store. OpenBuilds Modular Table Series | 3D Warehouse
  19. sharmstr
    The kit has 1680mm 20x60 (see the parts list OpenBuilds Table Series). If you want to buy that size outside of the table kits, you can email them.
  20. 22878
    22878 New
    The V-Slot rails on the build Rick posted are 1262.8 in length, which no size table uses, so I guess they would have to be custom cut?
    #20 22878, Jan 7, 2021
  21. Rick 2.0
    As noted above the drawing may not be dimensionally accurate. It was a quick mashup.
    Yes, the table from the shop is considerably larger than the LEAD 1515. It was morphed down to fit the system. You'll need to work the lengths out yourself. You'll probably get better measurements taking them off the original LEAD 1515 drawing.
  22. Rick 2.0
    Yeah, didn't notice that (as noted several times, it was a quick mashup). As there is no magic about where that rail sits you can either fudge it over a few millimeters or you can replace the fancy bracket with a triple L Bracket - OpenBuilds Part Store
  23. 22878
    22878 New
    I made a mistake on that measurement. The rails are 1472 in length. I just saw this on the 1515 part list:
    V-Slot Linear Rail - 20X40X1500mm, Silver or Black V-Slot® 20x40 Linear Rail 215-LP, Silver or 235-LP (2 cut to 1490mm & 4 cut to 1472mm)
    Are you actually required to cut the rails to these lengths i.e. 1490mm and 1472mm if you buy the bundle? OpenBuilds LEAD CNC Machine 1515 (60" x 60") Because I didn't realize that was part of the assembly.
  24. Rick 2.0
    In the stock kits everything is cut to proper length.
    If you need something cut to other than the lengths provided put a comment in the order section. They'll generally cut them for you. If you need a table cut down be very specific on what you need cut and to what length. Don't assume they'll read this thread nor do any research as they won't. What goes on in the shop is entirely separate from the forum.
    If you intend to cut down a table, I would suggest using the middle brace from the lower shelf as the 6th member for the top and using the extra 20x40s from the 1515 to form the lower shelf. No out of pocket that way. Should already come in the proper length.
  25. Rick 2.0
    ...or you could get a chop saw and cut them down yourself. Aluminum cuts like butter.
  26. 22878
    22878 New
    Actually, I didn't make a mistake. The 3 rails that run parallel on the legs are 1472mm, but the other two rails are 1262.8 in length. Is the work area not square? I assumed the rails were all the same length since all the builds have square dimensions like 60 X 60, 40 X 40 etc.
  27. 22878
    22878 New
    In order to build the legs/base and bed framing for this version I think I need these rails:
    7 X V-Slot Linear Rail - 20x60 - 1472mm - Silver
    2 X V-Slot Linear Rail - 20x60 - 1490.5mm - Silver
    2 X V-Slot Linear Rail - 20x60 - 1262.8mm - Silver
    4 X V-Slot Linear Rail - 40x40 - 790mm - Silver
    Does that sound right?
  28. 22878
    22878 New
    If I replace the 20X40 rails of the 1515 bed framing with the 20X60 rails from the table, using the middle brace from the table as the 6th rail for the bedding, then I think I would still have these rails left from the 1515:
    4 V-Slot Linear Rail - 20x40 - 1472mm - Silver
    2 V-Slot Linear Rail - 20x40 - 1490.5mm - Silver
    If I used two of the 1472mm for the middle bracing on the table, I still have 4 rails left, right? I'm wondering if it would be better to just keep the 1515 as it is and buy additional rails and brackets to make the table base. I think I would need these rails:
    3 V-Slot Linear Rail - 20x60 - 1472mm - Silver
    2 V-Slot Linear Rail - 20x60 - 1262.8mm - Silver
    4 V-Slot Linear Rail - 40x40 - 790mm - Silver
    And these brackets:
    8 40mm InsideOut corners
    16 60mm InsideOut corners
    And this hardware:
    128 Tee Nuts - M5
    128 Low Profile Screws M5 - 8mm
    And this component:
    Locking Caster Set
    Approx. pricing for the table parts according to the OpenBuilds part store would be:
    3 V-Slot Linear Rail - 20x60 - 1472mm - Silver $88.47
    2 V-Slot Linear Rail - 20x60 - 1262.8mm - Silver $58.98
    4 V-Slot Linear Rail - 40x40 - 790mm - Silver $107.96
    8 40mm InsideOut corners $22.32
    16 60mm InsideOut corners $47.84
    128 Tee Nuts - M5 $38.87
    128 Low Profile Screws M5 - 8mm $11.57
    Locking Caster Set $17.99
    Total: $394
    Doing it like this, there are no extra/wasted parts.
    If I buy the 1515 and 1515 table, I would have 4 or 5 rails left and 8 InsideOut corners and many nuts and screws left over. Plus, the 1515 table costs $651.99.
    But then I also have to consider whether using the 20X60 rails from the 1515 table for the bed framing instead of the 20X40 rails that come with the 1515 would be notably more sturdy. And using the 20X60 on top and bottom would also probably look a little better.
    #28 22878, Jan 7, 2021
  29. 22878
    22878 New
    The only measurement I'm worried about is the 2 V-Slot Linear Rail - 20x60 - 1262.8mm, since it's the only custom length used. I think the best way to get this measurement is to use the 1515 drawing and measure inbetween the outer side rails of the bed framing. I got a measurement of 1259.2. What do you all think? Does that seem accurate?
  30. Rick 2.0
    I think there is no magic to the exact location of those outer rails supporting the edges of the spoil board. Pick a number that works and carry it through. Make sure the rails clear the gantry plate and the connections fit in the corner. This will in turn determine the length of the lower front and back rails.
    I integrated the 20x60 framing into the base of the 1515 for a couple of reasons, some people have noted weakness in the 20x40 bed framing and having the 20x60s to connect the legs to meant a more rigid connection which will mean less wobble in the table.
    As far as leftovers you still need to budget in a side rail to support the drag chain alongside Y2. One of the original bed 20x40s laid flat and anchored to the front and back rails with a couple Black Angle Corner Connector - OpenBuilds Part Store will accomplish this nicely. If you don't like exposed ends you're also going to need several more End Cap - OpenBuilds Part Store to close off the extra holes on the 20x60s and the drag chain support.
    And finally the one item you're missing is the bottom plates on the legs that the castors fit into. I don't see them listed separately in the shop so you may need to make your own.
