V carve pro with black box ?
Discussion in 'General Talk' started by Tom Bellfoy, Jun 10, 2020.
  1. Tom Bellfoy
    Tom Bellfoy Well-Known
    Being new to openbuilds with my lead cnc, I am thinking of trying the v carve pro cad design software free trial version for now, will it be compatible with the blackbox ? So much to learn
  2. Giarc
    Yes. There is a grbl post processor for Vcarve. The BlackBox flavor of Gcode is grbl.
    And newer versions even have an OpenBuilds CNC Post (slightly modified from the Grbl posts - you can technically use either, the OpenBuilds one just has extra timeout for spindle spin-up, and gets rid of GCODES that Grbl does not support (M6 etc)
  4. Giarc
    Good to know. I bought Vcarve with one of my last OpenBuilds orders, but have not got around to using it.
  5. PeterPasse
    I have an older version of V Carve Pro 7.5. There are no p/p for Grbl. How can I get the Openbuilds Grbl to load into my V Carve? I just purchase an OpenBuilds Lead 1515 (awaiting shipping) and would like to use the V Carve that I have to design and send directly to the black box controller. Thanks Pete
  6. PeterPasse
    How can I get a download of the OpenBuilds P/p for V Carve Pro 7.5 ? Thanks Pete
  7. Alex Chambers
    Here;
    docs:software:vectric [OpenBuilds Documentation]
    Edit - just read your post properly the link (you have probably already found that out) is for a later edition of Vectric software. Don't know whether thaty works or not. Have you got a grbl (mm) (*.g-code) pp for your version?
    #7 Alex Chambers, Jan 9, 2021
  8. PeterPasse
    No, no P/p listed for any grbl on my version. Wanted to add it to My P/p in my version of V carve.. Thanks Pete
  9. Alex Chambers
    Have you tried the PP I linked to?
  10. PeterPasse
    Yes, there was a download for older versions. I downloaded it and copied it to My P/P in V Carve. I shut down V carve and started it again and got an error window that said: Config File, Unknown statement found in file on line 46 of file, C:\Documents and Settings\ll Users, Windows\Application Data\ Vectric\VCarve Pro\V7,5\My_PostP\OpenBuilds_inch.pp POST_BASE = "gRBL_INCH.PP"
  11. Alex Chambers
    Sorry - can't help much with that V7. 5 is before my time. Hopefully someone else will join in this thread. I never put a pp in "my pp" because it becomes the only one available - I always put them in the folder with the rest of the post processors.
    If I get time tomorrow I'll have a look at line 46 in that pp - could you please post it here? although there will probably be other issues with it. Have you tried asking in the Vectric forum?
    VCarve - General
  12. PeterPasse
    Thanks for your help. I have not posted in Vectric forum. What did you want me to post here? I don't know how to open the file to see the code. Any help? Thanks Pete
  13. Alex Chambers
    You said you found a post processor for an older version? Post it here and I'll have a look to see if I can see if it can be modified - depends what the statement Vectric is objecting to is. But asking the question in the Vectric forum might get a response from someone who is still using V7.5.
  14. PeterPasse
    It was in the link that you sent. There were options, first for current V Carve and option 2 was for older versions. I chose option 2, downloaded it and copied it to My_P\P folder. I don't know how to open it to see the code that it refers to. Thanks Pete
  15. Alex Chambers
    Ahh - no there is only the download for the latest Openbuilds post processor - option 2 says install ours, or use the built in pp's. I think you will have to ask on the Vectric forum unless another member of this forum can come up with V7.5 post processor for you.
  16. PeterPasse
    I found the code in the download that I used. It has a POST_NAME = "OpenbBuilds GRBL (Inches) (*.GCODE) and a POST_BASE = "Grbl_inch.pp" FILE_EXTENTION = "GCODE" UNITS = "INCHES" It is the POST_BASE THAT V Carve does not like as an unknown statement. What would it like for a POST_BASE do you think?
  17. sharmstr
    If no one can help you here, post a message or search the vectric forums for and older grbl post processor. Even if you find one, there's no guarantee that it will work. In looking at the current post (which you can open with a text editor), it doesn't like the line "POST_BASE = "Grbl_inch.pp"". That information will give you so detail to ask over in their forums.
    Edit: we replied at the same time. Here: What does the Post_Base command do
    That tells me that it also needs the file in the main posts folder. But since there is no grbl base post it errors. Perhaps take it out? Again, you might be better off over at the Vectric forums.
  18. PeterPasse
  19. sharmstr
  20. PeterPasse
    Thanks, I loaded it and no error windows. Made changes that were also in thread. Have to wait for my machine to arrive and will try it. Saved toolpaths from existing files and no errors either. Thanks Pete
    Alex Chambers, sharmstr and Giarc like this.
