OX PPR - Portable Plasma/Router
Discussion in 'CNC Mills/Routers' started by Steve B, Dec 28, 2014.
  1. Steve B
    Steve B Well-Known
    Steve B published a new build:
    Tom Allen likes this.
  2. Steve B
    Steve B Well-Known
    Attached are the changes to the original OX gantry plate.
    Hytech2k likes this.
  3. oni305
    oni305 Well-Known
  4. Steve B
    Steve B Well-Known
    Plates from Chris Laidlaw - My custom gantry sides and standard X and Z Axis plates. Also got a standard mount for Dewalt Router.
  5. Steve B
    Steve B Well-Known
    Making the Y axis motor plates. I cut a template from my laser cutter and used to drill 5mm holes in 1/4 6061. Then cut them out on a band saw. The leadscrew bearing ends got drilled in the wrong spot. I'll first use these plates for initial fit, and remake them once I know the geometry is right.
  6. Steve B
    Steve B Well-Known
    Change of plans on the OX PPR... considering a rename due to some recent discoveries. Most importantly, based on the CNC Jr. build, I determined that the structure here does not support portability. It needs to be fixed to the base. Also, since I am more interested in plasma than milling on this machine, I've decided on some changes to favor plasma cutting over milling. The biggest change is that the machine will be built upon a portable 4'x2' downdraft table. The table is started, a picture is below. Due to the changes, the leadscrew design is also looking less favorable. Considering reverting back to belt design. Though my geometry is different than a standard OX, I think the looped belt method will still work. 3D model will be updated soon....
    Paul Stoller and GrayUK like this.
  7. Steve B
    Steve B Well-Known
    Today I worked on motor/belt placement alignment. First picture shows geometry I am planning, second picture shows how the motor will actually be situated on the gantry plate. I think this should give me 25" cutting width and around 40-42" cutting length. The Y-Axis 80x20 v-slots will be oriented so that the bottom is level with the top of my cutting area. This should provide 2-3" clearance between the torch and the cutting surface, plenty for plasma. For routing, I think that if I remove the slats on my table (they are removable) and put a downdraft spoilboard down, I should have 4-5" clearance. In both modes, with the X axis low, the machine should keep rigid.
  8. Steve B
    Steve B Well-Known
    Update with a little more progress. Downdraft cart is all welded up with Y-axis rails in place. The gantry is being built and wired up on the workbench. The electronics box is also coming along....
    2015-06-28 16.08.50.jpg 2015-06-28 16.09.45.jpg 2015-06-28 16.04.29.jpg 2015-06-28 16.04.16.jpg 2015-05-23 14.29.52.jpg 2015-06-23 20.05.00.jpg
  9. Mark Carew
    Great looking machine @Steve B Looks to be very strong in design.
    All the best with your first steps :thumbsup:
    Mark
  10. Steve B
    Steve B Well-Known
    It's been a few months since I've worked on the PPR... but it's alive and kickin'. Today, all linear motion was checkout out and working and all the limit switches and homing procedure. I will still need to wire the LCTHC into it before I can start burning. Photos attached of the current progress.
    2015-10-15 15.18.51.jpg 2015-10-15 15.19.38.jpg 2015-10-15 15.20.19.jpg 2015-10-16 15.44.41 HDR.jpg
  11. stargeezer
    stargeezer Journeyman
    That's a awesome build! In the immortal words of Tony Stark - "I want one!". :)
    Larry
    Paul Stoller likes this.
  12. Giarc
    Great build! I like the electronics enclosure. What brand is it?
    -Craig
  13. Steve B
    Steve B Well-Known
  14. Steve B
    Steve B Well-Known
    I agree, 100%. I only paid about $45 for the box, but still a lot more expensive than I would have liked. Next time, I'll probably just laser cut a box.
  15. Steve B
    Steve B Well-Known
    A quick test video:
  16. Steve B
    Steve B Well-Known
    Here it is, the first actual cuts with the machine. There are still some serious issues to work out. The THC isn't working and if you watch closely on the video, the RF noise causes a considerable amount of USB noise, effecting the PC. It even zapped my video card on the last cut (which came back ok, thankfully!!). Thinking I need to fully isolate the PC from the cutting system.
    Paruk and swohnrade like this.
  17. Paruk
    Paruk Journeyman
    The Planet CNC cards are useless crap. I found that out the hard way with a Mark 2/4 and I suspect you're about to find out, too. You're going to be lured into a lengthy "support" route with no answers/solutions for you, but a lot of questions from him and blame to everything else but his card/software. At the end ultimate frustration will greet you. I'm putting it mildly now, the reality with this guy is worse. Why torture yourself and waste time? If the card is in pristine condition with no usage marks, try to get your money back!
    Consider going the Mach3 route. Software with a good quality BoB is cheaper or same as Planet CNC crap (Mach3 about US$ 175 plus about US$ 50 for BoB =US$ 225. Planet CNC Mark 3/4 with software = Euro 188 = about US$ 225) . Mach3 is a pretty solid platform, large user group hence lots of experience available to help and troubleshoot if necessary.
  18. Steve B
    Steve B Well-Known
    Thanks for the honest words, Prauk. I knew going into this that, especially with Plasma, that I might run into difficulty with the CNCUSB board. So far, though, none of the issues I'm having are related to his board.
    My biggest turn-off, based on experience a few years ago, to using Mach 3, was that I couldn't run it from a laptop. It just didn't work. I really don't want to invest in a PC JUST for the machine. I think now there's a good alternative with the Ethernet Smooth stepper and the Mach 3 combination. That's my alternative route, if this doesn't work out. It'd be about $400 to switch, which puts me out a little bit, but I can probably make use of the M3/4 board on another machine, or sell it.
    But, as mentioned, if this works, I'll stick with it, and the problems I am having don't appear related to the board. My biggest concern right now is that it seems that electrical noise is getting to my PC and keeping the LCTHC from working. I need to isolate that all out before anything else.
  19. Paruk
    Paruk Journeyman
    That's what I thought too, in the beginning of using the Mark 2/4. Then the process of elimination ruled out, one for one, all other possible causes. Costing me months of testing and trying, changing, etc. of my OX. In the end he finally admitted that the MK 2/4 was not suitable for the job and wanted to sell me a MK 3/4. I refused, of course. The MK 2/4 is no longer for sale now. I guess the same will happen with the MK 3/4 eventually.
    Having some old PC dedicated to the CNC will cost you maybe US$ 50 or less. Leave the essentials in, the rest out (hard- and software). No internet connections, no wifi, no music or videos, nada. It works great here with me, having no issues in the last months (except for some more fine-tuning).
  20. Steve B
    Steve B Well-Known
    Well, a lot has happened since I last posted. The plasma HF start causes major havoc on my electronics. The USB based control board was the first go - I quickly discovered I needed complete isolation to the computer. So, I got an Ethernet SmoothStepper and switched to Mach 3. I also tried different bread board and drivers, but they didn't do well with the HF noise, either. So, long story and several iterations later, I'm now at:
    - Ethernet SmoothStepper & Mach 3/Sheetcam (really nice, but added $$$)
    - Gecko G540 - Plasma HF was causing noise in the motor drivers I was using. G540 is metal cased and good quality. Haven't tested yet.
    - Extra BOB for e-stop and THC signals
    - Changed CANDCNC THC out for a Proma 150
    Mechanical changes - The belt drive system wasn't going to cut it. It caused many problems. The biggest of which is that the steps per unit on the belt drive system is way too low. But, I also had problems with belts and the gear adapter staying tight enough. I went back to my ORITINAL plan to use leadscrew drive. The X/Y axis are 1/2-10 10 TPI. The G540 is fixed at 10 microsteps, so that will be 20,000 steps per inch!
    Pictures are below. I haven't had a chance to run the system yet, but it's looking good. Hopefully this weekend I'll get a chance to start testing the new configuration out.
    FYI - The PlanetCNC M3/4 I have is FOR SALE, as well as 9 TB6600 based motor drivers and the CANDCNC THC that I have. PM me if you are interested. I think these are still VERY good for milling operations. Just not as good for plasma. I may keep the Planet CNC board for my mini-mill, we'll see.
    swohnrade likes this.
  21. Paruk
    Paruk Journeyman
    Well, I hope you're out of the woods with this setup. If you're of the masochist kind, keep the PlanetCNC for a mill (to find out it will most likely be consistent in malfunctioning!). I'll keep my fingers crossed for someone that will relieve you from it. It ain't me, though. ;)
    Try to keep your electronics away from the cutting table as far as possible, I would say.
    Looking forward to see your next video, this time with astonishing plasma cutting! Yeehah!
  22. Robert Kirkpatrick
    Hello. Been nearly a year since your last post. Any new updates? Would love to see this build finished :)
    jay1st likes this.
