The New "Smoothieboard" controller
Discussion in 'Controller Boards' started by bobt, Dec 28, 2013.
  1. bobt
    bobt Well-Known
    I have just received my new "Smoothieboard" controller.
    There is the first initial shots of the board. Now to get down to work and hook this up to the Shapeoko machine that I am going to use as a 3D printer.
    Bob
    Robert Hummel likes this.
  2. bobt
    bobt Well-Known
    Ok - did I get mine before you did Mark??
    Bob
  3. Mark Carew
    :D not sure Bob, I do have mine but have not had the chance to try it out as of yet. I have a ton of projects on the table now, but I do have plans for this one.
  4. The Dude
    The Dude Well-Known
    hey can the smoothie run a routy or OX which has been refitted with a multi-head spindle+plastruder+laser+picker+plotter+dragknife+??? without reloading the firmware? I realize there would need to be some extra gcodes added to tell it which head to use. An example might be a 3D printed circuit board that then has parts placed on it and then laser etched labeling, all in one run or maybe just stopping for a tool change.
  5. Mark Carew
    That's the hope :) I think the concept behind this board is great but it does still keep us in the NEMA 17 realm of things.
  6. bobt
    bobt Well-Known
    Only if you use the onboard drivers. There are break out connections to attach any other type of drivers to it.
    Also any of these operations are possible because all the code can be loaded. But that was not the original intent of the design. The original intent is to allow the controller to be used for any of these types of operations but one at a time. But you could do all of them it is just simple matter of programming (SMOP).
    Bob
  7. The Dude
    The Dude Well-Known
    what would be a good breakout board for running a nema23 off the smoothieboard? What are those things anyway? Like 10A?
  8. Mark Carew
    With this you could wire up most any of them out there like geckos for instance.
    http://www.geckodrive.com/geckodrive-step-motor-drives.html
  9. The Dude
    The Dude Well-Known
  10. Mark Carew
    Public Do Omens likes this.
  11. The Dude
    The Dude Well-Known
    #11 The Dude, Jan 14, 2014
  12. Mark Carew
    I guess if you dig in you could, not sure about how to go about that though. I am just thinking hooking up this drivers may be a quick easy way to drive higher amp bigger steppers.
    :D
  13. Public Do Omens
    Guest Builder
  14. The Dude
    The Dude Well-Known
  15. Public Do Omens
    Guest Builder
    What we need is to know what will drive what when and how.
    If we can find and consolidate all this information for all to share then this would help spread OPEN knowledge.
    This knowledge should not be profiteered from, like shop owners want.
    566 oz lift one inch from shaft now that is powerful!
    :cool: Times are hard lets share more FREE.
  16. bobt
    bobt Well-Known
  17. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Excellent info Bob, thanks for posting the link :thumbsup:
    Tweakie.
  18. Craig & Silas
    This looks very well done, have you completed the one for the CNC Machine?
  19. Rick 2.0
  20. Peter Van Der Walt
    These days, there's also a nice alternative:
    Instead of using Smoothieware (which is more of a 3D printing firmware) you can install Grbl-LPC : cprezzi/grbl-LPC - massively fast, works great and as its Grbl, works with all the more standard Grbl supported CNC toolchains, post processors, CAM, CONTROL, etc softwares
  21. Craig & Silas
  22. Craig & Silas
    Peter
    I have already purchased the Smoothie board as part of the C-Beam XL bundle, as I understand it should work with CAM and CONTROL. Is that true? Being new to this I do not know enough to understand the differences between the two boards.
    Craig
  23. Peter Van Der Walt
    Yes, if you install Grbl LPC as mentioned above onto it.
    Smoothieware / Grbl = firmwares
    Smoothieboard = the PCB
    Good to know the difference :)
    You can install GrblLPC onto the Smoothieboard.
