Interface module: Z-plus / Z-minus
Discussion in 'CNC Mills/Routers' started by Barzalou, Jan 23, 2021.
  1. Barzalou
    Barzalou Well-Known
    I've noticed that when I try to manually raise the Z-axis by pressing both Z buttons on the Interface nodule, it does not rise or lower consistently. By that, I mean that pressing the up button should raise it and the down button should lower it. Well, it consistently mixes itself up. Now, I do understand that I can manually configure the Interface to reverse the directions so the buttons can reflect our actual reality. But once this is configured correctly, at some point, it looses its mind and the buttons do what they want (anarchy !).
    I had configured my interface module to recognize the fact that my CNC is a Workbee 1510. I wonder the fact that my shop at night goes down to 42° and when I use it, back up @ 70°.... Could that be a factor?
  3. Barzalou
    Barzalou Well-Known
    Thank you Peter, I will check this tomorrow. In fact, I will check all of them. This is the second time I've had this issue of a loose wire and I must admit, it gets on my nerves. Thanks again.
  4. Barzalou
    Barzalou Well-Known
    Well, I found that I don't have continuity on the red wire going from the stepper motor to the BlackBox. I think, somehow, the issue could be at the stepper part of the length of the wire. I will cut it a bit and see if I have continuity again. I think that there was a "tug" of the wire when my z-axis went all the way up and unfortunately, probably severed the red wire in particular (because it was secured with a ti-wrap in the tidying up phase of the build).
  5. Barzalou
    Barzalou Well-Known
    Update.... That was the problem and now, it's working... Thank you.
