No GRBL Settings Tab v1.0.276
Discussion in 'Control Software' started by Michael Mertz, Jan 29, 2021.
Thread Status:
Not open for further replies.
  1. Michael Mertz
    This has probably been answered, but I have not been able to locate it. Over the last year and a half I have purchased the parts to build a Sphinx 1050. I am attempting to set up the Control software, but there is no GRBL settings tab. Can someone please explain to me how to correct this or setup the software for the 1050? I am currently unable to control the unit at all.
  2. sharmstr
    I'm taking a wild stab here but is there a chance that your controller isnt on com3? I dont even know if control can connect to something other than a grbl based board. Peter would know better than I, but I thought I'd chime in since he probably wont be around for a several more hours.
    It would be helpful to know your controller and your OS.
  3. Michael Mertz
    I am using the Blackbox motion control controller on Win 10. I am a complete noob on this so it could totally be on my end. I do not have any other option then com3.
  4. Michael Mertz
    This is what is displayed in the serial console at start up. It seems to connect fine to the controller but I am unable to actually make the motors move.
    Do you have another computer you can try?
  6. Michael Mertz
    Same issue on a desktop. It seems to connect, but I cannot control the unit. The Grbl settings tab is nowhere to be found. Is there a place I may be able to download an older version of the software?
    Grbl settings appears once Grbl responds to the $$ sent at connection time. This looks like the controller is locked up
    - test with other wiring disconnected, just the USB cable attached to controller
    - hit the Abort button to clear queue
    - send "$$" from Serial Console tab manually
  8. Michael Mertz
    Did the above on both computers. Nothing changed. I noticed that if I click "Send" nothing happens. If I hit enter, the code clears, but does not show as being sent on the serial console
    You can try an older version from github.com/OpenBuilds/OpenBuilds-CONTROL/releases
  10. Michael Mertz
    Is there a way to correct the controller if it is locked? Or am I just screwed and need to buy a new one?
    Before we get to that conclusion, we are doing a little testing, unless you are aware of some earlier event that could relate? (ie save the time testing if you know something happened to it?) more info helps us find a fix faster :)
  12. Michael Mertz
    I built the unit last week and found that I was missing a few parts for the drag chain install. Yesterday was when I received those parts and downloaded the software to try to test the unit. I was watching the video on how to setup the software and noticed I did not have the tab needed to set up the unit. The controller has been in the original packaging for around a year before the install. It is currently in an unconditioned space, but I do not see why that would affect the controller.
    So sounds like it should work :)
    Try an older version of CONTROL from the link above
    Keep the other wiring except the USB disconnected for now.
  14. Michael Mertz
    I did. It automatically updated to the lastest version. There was no change.
    OK, one last test:
    OpenBuilds CONTROL > Wizards and Tools menu > Firmware flashing tool.
    Select BlackBox, the correct port, 3 axis, no door switch. And click Flash. Screenshot the serial log tab when it completes (fail or success, both)
    If it flashed successfully, try connecting again
  16. Michael Mertz
    Flash Failed
    Ok, see
    Please, particular clues I intent checking on
  18. Michael Mertz
    [14:15:53] [ 3D Viewer ] WebGL Support found! success: this application will work optimally on this device!
    [14:15:53] [ websocket ] Bidirectional Websocket Interface Started Succesfully
    [14:15:54] [ update ] Checking for Updates
    [14:15:54] [ update ] You are already running OpenBuilds CONTROL 1.0.276
    [14:16:29] [ Firmware Upgrade ] connected
    [14:16:29] [ Firmware Upgrade ] reset complete.
    [14:16:29] [ Firmware Upgrade ] flashing, please wait...
    [14:16:30] [ Firmware Upgrade ] FLASH FAILED!
    [14:16:41] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [14:16:41] [ connect ] Checking for firmware on COM3
    [14:16:41] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [14:16:42] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [14:16:42] [ ] Grbl 1.1g ['$' for help]
    [14:16:45] [ connect ] Firmware Detected: grbl version 1.1g on COM3
    [14:16:51] [ disconnect ] PORT INFO: Port closed
    [14:16:52] [ Firmware Upgrade ] connected
    [14:16:52] [ Firmware Upgrade ] reset complete.
    [14:16:52] [ Firmware Upgrade ] flashing, please wait...
    [14:16:54] [ Firmware Upgrade ] FLASH FAILED!
    [14:17:09] [ connect ] PORT INFO: Port is now open: COM3 - Attempting to detect Firmware
    [14:17:09] [ connect ] Checking for firmware on COM3
    [14:17:09] [ connect ] Detecting Firmware: Method 1 (Autoreset)
    [14:17:10] [ connect ] Detecting Firmware: Method 2 (Ctrl+X)
    [14:17:11] [ ] Grbl 1.1g ['$' for help]
    [14:17:13] [ connect ] Firmware Detected: grbl version 1.1g on COM3
    [14:17:19] [ disconnect ] PORT INFO: Port closed
    [14:17:20] [ Firmware Upgrade ] connected
    [14:17:20] [ Firmware Upgrade ] reset complete.
    [14:17:20] [ Firmware Upgrade ] flashing, please wait...
    [14:17:21] [ Firmware Upgrade ] FLASH FAILED!
  19. Peter Van Der Walt
  20. Michael Mertz
    Thanks for your help.
  21. Robhoski
    Robhoski New
    In the same boat - tried to flash my control board with grblhal and lost the tab to grbl settings in Open Builds Control. Was looking to restore the factory settings after the flash failed and there was no way to get back to the saved settings page to revert. Will forge onward with alternate ideas to restore.
  22. Peter Van Der Walt
    1) Make sure your CONTROL is up to date (You posted in a thread about V1.0.276 from Jan 2021 - over 3 years and exactly 100 versions behind current - see title of thread)
    2) Grbl settings tab not shown just means you haven't requested Grbl Settings yet
    Disconnect and reconnect. (We send a request on connection)
    Or send "$$" on the Serial Teminal to refresh the settings.
    Or click the Reset button on the front of the BlackBox to reboot - if CONTROL sees the startup strings it will also request the settings
    Or reboot the PC - fresh starts always nice
  23. IngDonovan
    Hi, i have the same issue mine said the doors open and nothing happends
  24. Peter Van Der Walt
    1) if you configured a Door, close it to clear the alarm. If you do have a door disable accordingly
    2) don't use V1.0.200s which this thread is about. Use V1. 0.388
Thread Status:
