Nema 17 Belt and Pinion System
Discussion in 'Other Builds' started by Mark Carew, Aug 21, 2018.
  1. Mark Carew
    Mark Carew published a new build:
    GrayUK and MaryD like this.
  2. GrayUK
    So, :rolleyes: if I fix the Motor to a surface and support the other side, I could make the rail move forwards and backwards. :)
    I don't know why, but I'll give it some thought. :banghead:
  3. Mark Carew
    Yes you can do this and its really cool to see how it works in that config!
  4. Giarc
    Why? By mounting it on top the rock, you would have a much safer version of this:
  5. GrayUK
    Did you have that video in your collection!!?? :D:D:D
  6. Giarc
    All my "engineering" skills come from watching Wile E. Coyote. He is a Super Genius after all. It says so on his business card.
    AndrewAndersonOK and Mark Carew like this.
  7. GrayUK
    Don't fib! :eek: We all know that is your card with his name added. :D:D:D
  8. Sven Yonson
    I have lots of left over parts after upgrading one of my 3D printers, including Nema 17 motors. Will the Nema 17 belt and pinion system work with a CNC router build or is it more suited to laser engraving, lighter duty stuff? (Also, I'm guessing I'll be able to use a 2560/RAMPS setup with this as well? (because I have one laying around..)
  9. WilberMaker
    How is the belt anchored on the ends?
  10. Rick 2.0
    T-nuts and M5x8 screws. It is shown in the video.
  11. WilberMaker
    I went back to look and I don't see a video.
  12. WilberMaker
    I found it
    Rick 2.0 likes this.
