Workbee with Duet controller
Discussion in 'CNC Mills/Routers' started by Alex Chambers, Jan 15, 2019.
  1. Donald Oehlke
    Alex and Ryan, Yes I have tried to jog the X and Y axis and it does nothing. I can't get it to do anything. A remote session would be fine if we can find a time. Sure would like to make some parts.
  2. Ryan Lock
    Ryan Lock Veteran
    Hi Donald,
    Can you send me a screenshot of the bottom of your config.g file?
    Best Regards
    Ryan Lock
  3. Alex Chambers
    I have posted elsewhere on the forum about the peculiarities of the Oozenest implementation of the rep-rap firmware on the Duet controller - in particular the use of G54 as machine co-ordinates. This is modal (stays set until you change it) and I ran into a problem with it recently. I ran a job with no problems and wanted to run it again the next day. My machine was turned off overnight, but I knew it remembered workplace coordinates so homed the machine, jogged close to workplace zero and ran g-code. The machine headed straight for machine zero, snapping my bit as machine Z zero is below the spoil board. Obviously I had not changed to workplace coordinates.
    Alex. :banghead::banghead::banghead:
  4. sharmstr
    Maybe another way around this is to add G55 at the end of your homing code?
  5. Alex Chambers
    Good point, and one I intend to implement next time I wind up my workbee.
    Alex.:)
  6. Alex Chambers
    It's over two years since I started this build report, and I have learned a lot since then - from using the workbee and, not least, the Openbuilds forum. The latest experiment was cutting a replacement arm rest bracket for one of my sons' wheelchairs from mild steel on my un-modified Ooznest workbee - (Chinese clone) Makita @12.5 K rpm, 250 mm/min, 0.1 mm doc. Single flute 3 mm spiral upcut. Blue masking tape and superglue to hold the material.
    I could undoubtedly have gone faster and deeper, but didn't want to push my luck with a first attempt.
    sharmstr and Giarc like this.
  7. Giarc
    I have cut more steel parts with mine than I care to count. Always unintentionally...in the form of the sheet rock screws that are holding down my work piece. You intentional cut is cool! I have been meaning to try, but have not had the time yet to get to the project that requires it.
    #37 Giarc, Feb 3, 2021
  8. Alex Chambers
    I was a bit nervous about this, hence the cautious feeds and speeds, but the result is way better than anything I've achieved with aluminium.
