Fixed Gantry CNC Router
Discussion in 'CNC Mills/Routers' started by that-jim, Feb 4, 2021.
  1. that-jim
    that-jim Journeyman
    that-jim published a new build:
  2. JustinTime
    Looks very sturdy, Jim! :duh: :duh:
    This design is not used very often in the router world but rather in the 3d printing world since it needs a very big footprint for the same useful cutting length on the Y axis. But truth to be told, I have a machine that can cut 1200mm on the Y axis and, so far, I never used it. Max I used so far is 600mm. I could have built a machine similar to yours and get away with a smaller footprint. :)
  3. that-jim
    that-jim Journeyman
    Thanks, the footprint of the machine will end up at 700 wide and 760mm deep with a cutting area of 380 x 500mm. I could certainly get a bit more cutting area for the footprint with another style of machine but I am shooting for rigidity over size. I am going with this size as it is perfect for my basement work area (in an enclosure) and it should do most of the small projects that I want to do. I do plan on building a larger cnc router with a laser that will live in the garage.
  4. Rob Taylor
    I think fixed gantry machines are underrated in general by hobbyists, and would have been the way I'd gone if I didn't have some fairly specific multi-axis requirements. This looks very promising!
  5. Kevon Ritter
    Kevon Ritter Veteran
    I saw this and immediately thought, "I need to make mine bigger."
    KRE Mill V3 - Concept
    Since our builds are so similar, I should mention a few things that gave me grief.
    1. The Y rails and shaft need some kind of protection. I ran mine wet which made things a lot messier a lot quicker. Even using less corrosive fluids, I would avoid flood and strictly use air. I just didn't have a compressor.
    2. Make sure you cover up that Y motor and belt assembly for same reasons above.
    What spindle are you aiming for?
  6. that-jim
    that-jim Journeyman
    Your KRE mill looks awesome. Thanks for the input, I will plan on working something out for protecting the rails and especially the belt and motor. My plan is to use a 1.5kw 65mm air cooled spindle.
    Kevon Ritter likes this.
  7. Barsk
    Barsk New
    Hmm, I'm building a machine that resembles your Z assembly quite closely. What thickness of the Z plates are normally used on machines like this?
    I too use a 1.5 kW spindle.
    #7 Barsk, Mar 12, 2021
  8. that-jim
    that-jim Journeyman
    The z-axis that I have has a 15mm thick backplate at the sides the center is thinner to allow clearance for the ball-nut. . I had this unit on another machine so I thought I would use it because I am unable to build on this nice. This unit is made to use v wheels so I have made a adaptor plate out of 9mm plate to fit it to the linear bearings.
    The first machine that I built, I build I bought the parts as kind of a kit, they were 6mm thick. I think if there is a normal it would be around 9mm. Hope this helps.
    #8 that-jim, Mar 12, 2021
  9. Barsk
    Barsk New
    Ok, thanks!
    Seems that in Europe alu plates cames in standard thickness of 8 or 10 mm, so I'll have to choose a thickness from that. 10 or 8, hmmm. :)
  10. that-jim
    that-jim Journeyman
    I would get the 10mm, if you have to face it off to make it flat you will have extra thickness to work with.
  11. Barsk
    Barsk New
    Yes, going for 10 mm. Thanks!
