LEAD CNC 1010 - Eccentric Spacers Not Doing The Job
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Feb 6, 2021.
  1. Scott Thompson
    Does anyone else have this problem. With my system now fully assembled I began the process of adjusting all of the eccentric spacers. On some assemblies even when the eccentric spacers are turned to their maximum position the wheels are still too loose. Not sure what to do now.
    Scott
  2. Alex Chambers
    With the eccentrics in their loosest position, loosen the screws holding the wheels to the plates, push the wheels firmly towards the C-beam and re-tighten the fixing screws. Then see if the eccentrics will adjust correctly. Let us know if that doesn't work.
    eric bultman likes this.
  3. Scott Thompson
    Thanks Alex I will give that a try and get back to you
  4. Scott Thompson
    Hi Alex that solved the problem. Thanks for the excellent advice.
    Scott
  5. OICITNOW
    OICITNOW New
    Just the question i was looking to be answered!
