Interface Not Recognizing USB Drive
Discussion in 'Interfaces' started by Rob Heckman, Feb 6, 2021.
  1. Rob Heckman
    I have the interface up an running but it does not recognize my USB Drive.
    I have the wireless connected and have update both Control and Interface Firmware to the latest version but the bottom left of Interface show "no usb drive." The Drive light on Interface is also not illuminated. I have formatted two different drives (including the one that came with Interface) with FAT32 and prepped them using the wizard in Control. I have checked the USB port on Interface and it does not appear to have any buildup pr foreign particles in it. Everything else seems to work fine outside of I can't get it to recognize any USB drive. Any help would be appreciated.
  3. Rob Heckman
    I tried to "pinch" the usb to make it fit more snug, but it still does not detect any USB drive that I connect. It does fit noticeably tighter but does not register on Interface. I have tried 3 different drives, all formatted FAT32, all prepped through the Control wizard, none register on Interface. The drives I have tried:
    1 - OEM drive that came with Interface
    2 - Sandisk 15 GB
    3 - PNY 256 GB
    Thanks, then next step is to reach out to the Store: http://support.openbuilds.com/support/home
  5. IndyMaker
    IndyMaker New
    Exact same issue and circumstances for me today when I tried to use. Sent message via contact form, but wanted to capture here as well in case there may be something broader to learn here.
  6. BeeAMaker
    BeeAMaker Well-Known
    I had the same issue yesterday. I inserted the Drive into my laptop to make sure there wasn't something wrong with the drive, all was OK. Placed it back into the Interface and worked since.
    Also want to note that before I was not connected to WiFi. when I put it back in after the laptop, I was connected to WiFi. Just info.
  8. woodjoiner22
    I
    Have you fixed your problem? i have same thing except the usb lcon lights when i insert a usb drive it just doesnt recongise it. The supplied usb drive always works now on my repacement unit i just carnt use any others
  9. woodjoiner22
    i sorted the issues i was having with my new interface not reading the usb drives all it took was for me to format my fash drives with "verbatim FAT32 Tool" now my interface will read all my drives straight away all the time. Just thought id share incase it helps somebody else
  10. Andrew Geeting
    I've had the same USB issue with mine among other issues. Still waiting on a response back from support. The USB worked the first time I plugged it in but after that the interface will no longer recognize it.
    If its been more than 24hrs, check your spam folder, or log a ticket at support.openbuilds.com - they are very quick
  12. woodjoiner22
    did you try formatting your drive with verbatim FAT32 Tool?
  13. jdizzle
    jdizzle New
    Hello,
    Can I add my name here too. Used the interface for the first time today. First cut worked perfectly with the supplied USB. Now nothing wants to connect. Have tried to squish the end of the USB as Peter suggested, have used Verbatim formatting software... nothing yet the device recognises the USB is plugged in because the USB power led is on.
    Speak to http://support.openbuilds.com/support/home please they will be happy to assist
  15. jdizzle
    jdizzle New
    Thank you, have done that. Lets see what happens next.
  16. JayMcD
    JayMcD New
    I have the same problem. Was working fine. Connected to the interface through wifi browser interface now the USB light is always on and it boots and NO USB and does not see the USB drive. I am going to try to format again with the USB Formatting tool and see what happens.
  17. BeeAMaker
    I want to add, when the temp in my shop is below 45 degrees F, the drive is not recognized on first boot up. I have to reboot the black box and then it is recognized.
    I now get my heat going first and wait until the temp is above 45 to turn on the machine.
    Please contact the store via Support and they will be happy to resolve the issue for you
  19. JayMcD
    JayMcD New
    Thanks Peter. Is this a common problem? Is it likely aboard issue or ?
  20. JayMcD
    JayMcD New
    Well, interesting, it was pretty cool in my garage yesterday. Probably about 1 or 2 degree Celsius .
  21. Peter Van Der Walt
    Not very common, the store will run through Troubleshooting with you to find the cause. Thanks
  22. JayMcD
    JayMcD New
    Seems to work when it is warm... Very sensitive to cold I guess.
  23. BeeAMaker
    Would be interesting to see what the data sheet says for the interface chip operating temp. Could be the drive itself I guess too. I haven't tried bringing the drive in to stay warm.
  24. RamonCC
    RamonCC New
    HI all, I know it is a very old post and maybe not relevant anymore, but it was relevant to me today.
    I have a rat rig CNC with a blackbox controller X4 with the interface which I bought long time ago but only started to use it recently
    It is working fine except that the USB drive was not recognized. Tried all the steps, formatting and stuff.
    What worked for was running the Device Test mode, so rebooting and holding the MODE button.
    The interface now recognized the USB disk and the icon turned green.
    After this everything was fine
  25. Peter Van Der Walt
    Probably just the action of removing and inserting the drive during the test that wiggled the contacts, not the test itself (that literally just tests each thing it asks for. Doesn't change anything)
  26. RamonCC
    RamonCC New
    The USB was not recognized, stayed in the Interface, did the test and it worked without touching.
    Even wen taken out and back in again
    But you are right, I was trying it again, same issue. What does de pinching method mean?
    (I have V2.10, so no Q25 issue)
    Better to contact support? (Or maybe live with it...)
  27. Peter Van Der Walt
    B
    Yes contact support :) thanks
