Xtension Limit Switch Stopped Working
Discussion in 'General Electronics' started by MalcolmN, Feb 15, 2021.
  1. MalcolmN
    MalcolmN New
    Hey all!
    My Z axis Xtension Limit Switch randomly stopped working. I put in a tech support ticket, as well as went ahead and put in an order for 2 new ones so I have at least one backup. But are there any tricks I can try in the meantime so see what might be wrong? The wiring from the Black Box to the switch is good still. I tested by moving my x axis switch to the z wiring and it worked. And the Z switch on the X wiring still doesn't work so I limited it to the switch itself. Thanks!
    Did you have a hard crash into it? We have seen that damage the switch
  3. MalcolmN
    MalcolmN New
    No sir! Homed machine, ran a job. Completed the job just fine. Went to send it home and it didnt stop. Hit the estop, then powered it all back up to try to troubleshoot.
