Gantry move issue
Discussion in 'CNC Mills/Routers' started by Barzalou, Feb 15, 2021.
  1. Barzalou
    Barzalou Well-Known
    Hi everyone, I'm having an issue with my Workbee. As I fixed grub screw issues, and noticing that some wires had gotten loose from their connectors, I fixed all of them correctly and inserted them back in the Blackbox. As I'm trying to move the gantry along the Y axis, I get a disturbing shaking from it as I do. When I unhook one of the 2 stepper motors leaving one alive, it moves without a hitch (one stepper does the work, obviously). I checked to see if I have continuity with the wires which I do. Can someone tell me if I should jump out the window? Have a look and listen to the video I added.
    Thanks.
  2. sharmstr
  3. Barzalou
    Barzalou Well-Known
    I thought this was the issue so I checked for continuity and everything is fine. I will check again....
  4. sharmstr
    Continuity isnt the only thing to check though. I've had this happen once and it was two wires sticking out to far and arcing. That scenario passes a continuity check.
  5. Barzalou
    Barzalou Well-Known
    Ok, I will check.... Thanks....
  6. Barzalou
    Barzalou Well-Known
    Well, it was a wiring issue even if things seemed ok for the continuity test and even if it looked that the connection was not on the plastic of the wire. I undid the wire to the connector, cut and stripped the 4 wires and set them back in the connector and.... Well, it.... Works.... Thanks for the guidance and help.
