Help needed with OB Vectric post processor
Discussion in 'General Talk' started by FrankM2020, Nov 4, 2020.
  1. FrankM2020
    Hello all. Need help with adding a delay to allow vfd spindle to come up to speed before starting job. Have searched the forums, still can’t figure it out. Appreciate any help. BTW I’m using OB PP for Vectric v carve pro
    Checkout Post Processor Editing
    We have a 1.8 second spinup delay (which is enough for most spindles we use) so you can edit that line and just change the 1.8 to a longer period for your own modified post
    FrankM2020 likes this.
  3. FrankM2020
    Peter, Thanks for your reply. I'm not very savvy at Gcode or any programing for that matter! The article you refered me to kinda blew my mind. however I did find 1.8 sec delay you spoke of and changed it in OB PP to 5 sec. when I run the file using the updated PP it delays the start of job with spindle off then proceeds to run job as spindle ramps up.
    appreciate your help getting this sorted.
    Make sure the G4 delay command is After the M3 Spindle On command
    Code:
    begin SPINDLE_ON
    "M3[S]"
    "G4 P1.8"
    attach your edited post, and a gcode file created with the edited post if you want me to check it out :)
  5. FrankM2020
    + Command output after the header to switch spindle on
    begin SPINDLE_ON
    "M3"
    "G4 P5"
    this was copied from PP that i changed . no change noticed when running job. it appears that I've done it correctly,
    Please attach and I'll check
  7. FrankM2020
    Attached
    #7 FrankM2020, Nov 4, 2020
    Right, so from your gcode:
    Line 7 is a 1 second pause
    Line 8 turns on the spindle
    Line 9 is a 10 second pause
    Then the XY moves start
    Looking at the Post processor:
    Line 103 is the 1 second pause
    Line 112 is the spindle on
    Line 113 is the 10 second pause
    Loaded file up on my machine (equiped with a router, I don't own a VFD)
    Moved Z to about 0.2 inches above the stock
    Moved XY to the first plunge point
    Waited 1 second
    Router turned on, it waited in place for the full 10 seconds
    Started plunging down and running the XY moves
    Moved in XY to above the plunge
    So all the gcode related actions are working as intended.
  9. FrankM2020
    thanks for the help. I'm still having the same issue in spite of the gcode being correct! the controller ignores the G4 p10 line
    I must be missing something somewhere in the setup. unable to run if spindle comes up to speed after cut starts.
    if you think of something I'm doing wrong, let me know please.
    thanks again
    1) Try G04 instead of G4 just in case?
    2) Make sure you are loading the correct file (not an old one with the same name maybe)
    What controller are you using?
  11. FrankM2020
    i'm using the blackbox controller
    Same here in the tests (also using BlackBox) - Grbl doesn't mind G4 vs G04
    So double check the Gcode editor tab after loading your file that you do have a pause after the M3
    And then maybe something in your VFD parameters causing some extra delay? (like it gets the signal, then waits 10 seconds to start, gcode also waits 10 seconds, but now its all happening at once? Or its just ramping up much slower than 10 seconds? Look at delay/ramp keywords in VFD manual)
    You can test this from the Tool On menu in CONTROL - see if it responds in a timely fashion
    #12 Peter Van Der Walt, Nov 4, 2020
  13. Rob Heckman
    Peter
    Was this ever resolved? I seem to be having the same problem. I am using the open-builds black box with a VFD. This is what my code looks like in Gcoder editor:
    T1
    G17
    G20
    G90
    G0Z0.8000
    G0X0.0000Y0.0000
    M3S18000
    G4 P8.5
    G0X1.1275Y0.7500Z0.2000
    G1Z-0.0750F30.0
    G1Y4.7500F60.0
    G1X1.1276Y4.7594
    The problem is that even with the G4 command after M3, When I hit Run Job in Control, the spindle pauses for 8.5 sec and then turns on. This doesnt give the spindle enough to time to spin up and causes it to "drag" the wood. I have also tried G04 but that has no effect. Any suggestions?
  14. Giarc
    How did you get the P8.5? That is where your 8.5 second delay is. This is what Vectric spits out for me when I use the Grbl mm post processor:
    T1
    G17
    G21
    G90
    G0Z59.000
    G0X0.000Y0.000
    M3S18000
    G4 P1.8
    With the OpenBuilds inches Post Processor I get the same 1.8 seconds:
    T1
    G17
    G20
    G90
    G0Z2.3228
    G0X0.0000Y0.0000
    M3S16000
    G4 P1.8
    #14 Giarc, Feb 23, 2021
    1.8 is for our recommended routers. VFDs are 3rd party items, if you go beyond standard setups, you may also just need to copy and edit the Post to suit your now different spin up times :)
  16. len civitano
    So I'm changing to a spindle and reading up on PP editing. I feel confident this is well within my abilities but I feel like I'm missing something fundamental and basic. I'm editing the OB Vectric PP to include turning on the cooling relay (M8, I believe) as well as adding a 7 second delay (G4 P7) to allow for spindle spool up. What I don't understand is this......why is there no footer in the OP PP? I open it n the text editor and see no footer at all. Wouldn't instructions on how to end be found there? How does OP Control know to shut down the spindle/router without this information? It was turning off my router automatically before so clearly it's not an issue but I also want to add the command to shut off cooling at the end of the run. So, why no footer? What am I missing here? Thanks!
  17. sharmstr
    The OB post defines any overrides of the default post. You'll see in the OB post that there is a POST_BASE defined. That POST_BASE has the footer. So, if you want to change the footer, add it to the OB Post.
  18. len civitano
    I knew I was missing something! In looking over a bunch of documents at midnight with a little vodka in me I must have missed this. So........just so I can get this straight in my own brain, there is a default post processor which contains a footer (presumably with ending instructions). The Openbuilds post processor has no footer therefore it defers to the footer in the default post processor which becomes part of the gcode. If I add a footer to the Openbuilds post processor, it will override the footer in the default post processor. I assume I should be able to find this default post processor in the PP folder where Vectric stores them (just to take a peek)? And to clarify further. The addition of a footer to the Openbuilds post processor doesn't add to the default footer, it replaces/overrides it? Do I have this right? I realllllllly appreciate your help. This kept me up last night, despite the vodka.
