Blackbox LED red
Discussion in 'CNC Mills/Routers' started by Barzalou, Feb 23, 2021.
  1. Barzalou
    Barzalou Well-Known
    Hello,
    As I'm trying to get the Workbee working correctly, having made sure that everything is connected correctly, when I turn the power supply, it turns on correctly (and yes, it's set correctly to 115v), the BlackBox has the power LED turn RED (switched on or off).
    What could be the cause for this?
    Thank you
    The power LED goes red when you have the 24v wiring polarity wrong. + and - is swopped.
  3. Barzalou
    Barzalou Well-Known
    Thanks Peter, I will check this tomorrow. Have a good night.
