X axis quit working black box
Discussion in 'CNC Mills/Routers' started by chuck english, Feb 25, 2021.
  1. chuck english
    Hello. What would cause my x axis to quit working? I have checked all connections closely... It was working fine and then started doing like it is in attached video.
    thanks!
  3. chuck english
    You are correct. The connection where the wire goes into black box terminal was apparently not making good contact. I haven’t come up with a good reliable way to connect to those screw in terminals. Is there a correct way to connect?
    Are you sure you open the terminal before inserting the wire? If not, you can insert the wire under the cage its supposed to be inside of. Take a connector in hand, play with the screw and see how it functions. Then make sure to insert the wires into the cage, tighten properly, and it should be good for years to come
    See
