information on graving on aluminium padlock
Discussion in 'CNC Projects' started by roxane deziel, Mar 2, 2021.
  1. roxane deziel
    i would like to engrave on a aluminium padlock but when we engrave the pointer does mark twice on each letter.
    i would like that it would that the tracer would run only once.
    witch font can i use
    the dimension of the surface is 30 mm with and height 10 mm
    for an example the mane to wright is MAINTENANCE
    THANKS
  2. jeffmorris
    jeffmorris Journeyman
    Practice on a piece of material the same size as padlock. I think "MAINTENANCE" is too long. You may have to use single-line font.
  3. roxane deziel
    thanks for your reply. the thing is that I am looking for a single-line font in the software and I can't find one.
    do you have an idea for a font?
    thanks for your help.
    OneLineFonts, The source for single line fonts alongside a CAM that known to handle single line vectors
  5. roxane deziel
    is it possible to add font to cam.openbuilds.com? does it support the single line fond?
    OpenBuildsCAM requires closed Vectors, sorry
  7. roxane deziel
    ok, thanks for your help
